Go to Post Sure, it's just a robotics competition, but some of us actually care about the robots... - Karthik [more]
Unread 07-01-2012, 23:48
Apeace Apeace is offline
FRC #1123
Apeace is an unknown quantity at this point
Wheel Size?
I just noticed that the rule book has no mention of the wheel size constraints. Any thoughts?
Unread 07-01-2012, 23:52
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
Team Role: Mechanical
the man is on a distinguished road
Re: Wheel Size?
I think it may be possible to get over the 4" bump with no restrictions, besides I guess a 38" wheel...
Every day is a new adventure!!!
Unread 07-01-2012, 23:53
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Re: Wheel Size?
You can make your robot have two bike wheels and it will be fine assuming that you can program your robot to stay balanced at a flat angle.
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 07-01-2012, 23:54
the man's Avatar
AKA: Jacob Overla
FRC #4004
Re: Wheel Size?
Did some one say segway bot?
Andrew Lawrence
Posts: n/a
Re: Wheel Size?
As long as none of your wheels are above 60 inches in diameter, I'm sure everything will be just fine.
I so want to use 60" wheels now!
Unread 07-01-2012, 23:55
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
Re: Wheel Size?
But the wheel needs to be contained in the bumper perimeter... Or did that change this year?
Unread 07-01-2012, 23:56
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Re: Wheel Size?
I don't want to rain on your parade, but they couldn't possibly be any larger than 36 inches in diameter if you plan on building a 28x38 inch frame around them.
the man's Avatar
AKA: Jacob Overla
FRC #4004
Re: Wheel Size?
That why I said 38" the maximum no height dimension.
Unread 07-01-2012, 23:59
FRC #1123
Re: Wheel Size?
So it sounds like you could use larger wheels to get over the barrier much easier?
Unread 08-01-2012, 00:00
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
Re: Wheel Size?
Other than design constraints, nothing is stopping you from doing it.
Unread 08-01-2012, 00:05
Flimsor's Avatar
Flimsor Flimsor is offline
The Mad Cadder
FRC #1983 (Skunkworks Robotics)
Rookie Year: 2011
Flimsor will become famous soon enough
Re: Wheel Size?
I think we should use a custom sized tank drive system that is the exact maximum dimensions allowed. That way, if the robot gets flipped over it can still drive, and we can get over the bump.
Unread 08-01-2012, 11:14
ThaineP
Posts: n/a
Re: Wheel Size?
You should totally make adaptive-geometry wheels to get over the bump in the middle.
Unread 08-01-2012, 12:28
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Rookie Year: 2011
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Re: Wheel Size?
How about a Tweel?
They might be used in future lunar rovers, so they should be good enough for FIRST.
Unread 08-01-2012, 15:19
couvillion couvillion is offline
FRC #1818
Rookie Year: 2011
couvillion is an unknown quantity at this point
Re: Wheel Size?
Along the lines of cool and not really helpful.
I have not been able to come up with a engineering reason as to why tri-star wheel is better than a regular wheel of the same over all size. But like the design all the same. For those that aren't sure what is going on here it is the same setup as a planetary gear system with the ground acting as the ring gear.
  #15   Spotlight this post!
Unread 08-01-2012, 15:41
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
Re: Wheel Size?
I remember seeing an old 2004 clip on youtube with a bot that used them to climb the stairs...
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
