Re: The Barrier Thread
My question on math was how we would calculate if a wheel can climb a surface, my bad.
Then you'd be comparing the net upwards force (acceleration and friction) to gravity.
look at my signature link click on update 7 and see our video of what we were trying to do today.
But you had that little thing in front. Do you think something similar will go through inspection?
It will be underneath our bumper.
To everyone who thinks you can cross the bump unaided (that video shows what lifting the robot before the wheels hit can do) with 6" wheel, I'm fairly sure that is wrong. The center of your wheel is 3" off the ground and as such you would ram flat into the metal. MY guess is that you'd break the wheels or send your robot hurtling head over heels before it would go over the bump. Even a 8" wheel would be sketchy, because it is level with the top of the metal. To be certain you would need 10" wheels.
or you can have pneumatic wheels
I was thinking about this too, the 8 inchers from AndyMark are lookin' especially nice right about now...
If you actually do the math and check your geometry, you will come to the conclusion that a 8wd 6" wheel will definitely clear the 4" "Bump". Also there are a lot of ways with 4"-6" wheels you can clear it. 10" wheels would be a bit overkill. -RC |
#10
Yeah, our feeling is that just throwing more wheels at the problem would be more effective than massive wheels.
#11
FRC gamers are so used to nice flat surfaces (for the most part) we hardly ever think of a standard vehicular feature ---- suspensions. I'm looking forward to see what the 6WD fans do for this year.
#12
But what if you load your robot with an extra 90 lbs?
EDIT: And it also breaks the bumper rules; those are uncovered corners. |
#13
And the other two are correct; you're violating bumper rules and your robot is very lightweight. In addition to this, because the person on the left didn't hold onto the strip, your robot is not taking as much force. Also, the repeated attempts will put a large wear and tear on your wheels/robot. How would you manage to put the bumper around that while still having an effect? Last edited by Duke461 : 08-01-2012 at 00:58. |
#14
it is a prototype on the first day and we have other thoughts of getting over the barrier.
come on we have not thought of everything yet just wait in the next couple days we will have something. |
#15
No one was dragging you down for not considering the entirety of a design; they were just pointing out the possible flaws before you found them later on...
