Go to Post I do know that I cringe every time someone brings up "lawyerism" or some other such nonsense as the reason their interpretation of the rules is right. - Kris Verdeyen [more]
Unread 08-01-2012, 15:20
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
Team Role: Mechanical
the man is on a distinguished road
Re: The Barrier Thread
I think he was being slightly sarcastic.
Every day is a new adventure!!!
Unread 08-01-2012, 21:39
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
If you had 6 inch wheels, you would still be able to drive up the rail like this.
http://www.youtube.com/watch?v=3qWYAOGZVM4
Not necessarily recommending it, but it is using small wheels to drive up a large obstacle.
If one was to use Gates belts, would tensioning them be a problem when the barrier pushed into them?
I think high centering could be a large problem. Could this be solved if you had a convex bottom part of your frame so it had a turtling effect (not stable so it doesn't balance when resting on the frame between the wheels)?
Unread 08-01-2012, 22:51
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
If anything, it would increase tension, possibly to the point of failure. Technically, this would be a "tensioning problem", but not the one people normally think of, also, it could easily be reduced by adding idlers to the belts where they are exposed so that the belt is pushed into the idler rather than into nothingness.
Unread 10-01-2012, 00:34
krazyman1013's Avatar
krazyman1013 krazyman1013 is offline
FRC #0701 (RoboVikes)
Team Role: Leadership
krazyman1013 is an unknown quantity at this point
Go on the bump at an angle with 6" wheels and you can clear the bump without damage.
Unread 10-01-2012, 00:36
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Can you clarify and demonstrate that, please?
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 10-01-2012, 01:13
dez250 dez250 is offline
54... What a good number!
Rookie Year: 2000
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
I'm putting it out there and betting the majority of teams who weren't around for 2004 who try to climb over the barrier will end up like below.
You need to plan for worst case scenario, other robots contacting you and obstacles in your way as you try to traverse the barrier, if you choose to go that way. Trying to cross the barrier in your lab in a best case scenario would be as effective to your team as practicing your robot shooting at the hoops using a football.
Oh and for those of you who think you will not have damage to your robot if you just try to plow over the barrier at high speed, I suggest you do a real world simulation of this. Go find yourself some road hazard strips like this (or a simple curb) and feel the result of going over those even at 10 MPH. I think you will be surprised at the second thoughts you might have at just plowing into the barrier then.
-Michael Dessingue
Unread 10-01-2012, 01:57
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Well, automobiles have a suspension typically, and honestly driving fast over most normal speed bumps works just fine. I'm not so sure I'd do it with a curb, at least not in my own car.
Unread 08-01-2012, 00:48
thejoker2605 thejoker2605 is offline
FRC #2605 (Sehome Seamonsters)
Rookie Year: 2010
thejoker2605 is an unknown quantity at this point
We are thinking that with big enough wheels the barrier shouldn't be to rough. I think it will be important to avoid traffic jams at the bridges but not important enough to warrant another system.
