Go to Post Does this mean it's too late to ask for a flux capacitor? - Peter Matteson [more]
Unread 08-01-2012, 01:37
salomon90's Avatar
salomon90 salomon90 is offline
AKA: Bryan
None #0005 (GO FIRST)
salomon90 is on a distinguished road
Does embedded computer count as controller?
Hi, I'm wonder from ambiguity of rule
[R52] Robots must be controlled via one programmable National Instruments cRIO (part # cRIO-FRC or
cRIO-FRCII), with image version FRC_2012_v43. Other controllers shall not be used.
if an embedded computer/micro-controller that is only pipping raw data from sensors to the cRIO as a recognizable format count as a controller thus making it illegal.
It would seem since it's not being used as a controller and is not controlling any aspect of the robot that one may consider it a custom circuit that feeds sensor data to the cRIO via the second Ethernet port which is open to team use as of [R53] B. Past threads people talk about this topic, but they all seem up in the air about it also, so I would like some more certain answers.
~MN GO FIRST Alumni Organization
-University of Minnesota- Twin Citites
-Electrical Engineering Undergrad
2009 - Team 2526 Crimson Robotics Programming
2010 - Team 2526 Crimson Robotics Electrical / Drive Team
2011 - CARD Team #5 GV Design/ Mechanics
2013 - GO FIRST Director of Research and Development
"Sounds like the future."
Unread 08-01-2012, 02:56
WizenedEE's Avatar
WizenedEE WizenedEE is offline
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Team Role: Leadership
Rookie Year: 2010
WizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to all
Re: Does embedded computer count as controller?
They are obviously intending to allow laptops onboard the robot (<R36> says you can use laptop batteries), so...
Specifically, I think a controller would just be anything that controls the motors. The MaxBotics rangefinder we got in the KOP has a "controller" on it, and that's fine.
Unread 08-01-2012, 04:40
mesamb1's Avatar
mesamb1 mesamb1 is offline
AKA: Sam Bacon
FRC #1466 (Webb Robotics)
mesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nice
See the whole rule
[R36] The only legal source of electrical energy for the Robot during the competition is one MK ES17-12 12VDC non-spillable lead acid battery, or one EnerSys NP 18-12 battery, as provided in the 2012 KOP. This is the only battery allowed on the Robot.
Batteries integral to and part of a COTS computing device are also permitted (i.e. laptop batteries), provided they’re only used to power the COTS computing device.
Unread 08-01-2012, 03:03
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
If the cRIO is performing all of its required functions, and peripherals that may only be connected to the cRIO (e.g. modules & breakouts) are so connected, then the cRIO is being used properly. For the functions that are left you may use the auxiliary controller, provided it meets all the rules (particularly custom circuits and cost accounting).
Your proposed use would be legal—you may think of the custom circuit as everything starting from the wires connected to the PDB (for power) and the Ethernet port.
Remember that if you buy the embedded computer/controller as a unit, you must account for it as a unit. If you buy individual parts and assemble those, you must account for them separately. This can be critical for compliance with the $400 limit.
