New version of the Windriver update posted
There was an error in the installer that was posted for the C++ WPILib update to Workbench. It was missing the WPILib.a library. A new version has now been posted and is available on FIRSTForge.
http://firstforge.wpi.edu/sf/frs/do/...2_update_for_c Sorry about the mistake. Brad |
Re: New version of the Windriver update posted
Brad,
I don't see any files when I follow that link. KC |
It's back now. There was an error when I gave it a test. I got nervous and temporarily removed it. It turned out to be an older image on my cRIO, and I replaced the update. Let us know if you have any issues.
Brad Last edited by BradAMiller : 01-08-2012 at 08:47 AM. Reason: typo |
Thanks Brad!
-Collin, 1138 |
So I've got the two new .zip files from NI, but they are password protected. What is the decrypt password?
Thanks, bob |
Ok - the password is the one from kickoff: !HotShots!KnowBalance!
Now...next problem -- I got the program to run and find my cRIO no problem, but I can't find the FRC_2012_*.zip file. Where is it? Thanks, bob |
Aha!
So, for C++, Brian mentioned the NI updates in links here.... http://firstforge.wpi.edu/sf/frs/do/...2_update_for_c but there is also a link at the bottom of that page which is the actual C++ workbench update that contains the cRIO image in it at: http://firstforge.wpi.edu/sf/frs/do/...h_update_v2993 |
How do u decrypt the d link from last years competition?
Plug a laptop via Ethernet into the switch on the Dlink. Then using a web browser connect to it, should be 10.x.y.1. The from the web setup pages turn off WPA encryption.
Brad |
