Go to Post Progress should never made at the expense of the past. - Koko Ed [more]
Unread 08-01-2012, 10:12
CliffyTheGamer's Avatar
CliffyTheGamer CliffyTheGamer is offline
FRC #4070
CliffyTheGamer is on a distinguished road
Bridge building help!!
Team 4070 is a rookie team and we need help with how the bridges work so we can build one for our practice field. Any diagrams or helpful information would be greatly appreciated.
Unread 08-01-2012, 10:13
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
Team Role: Mechanical
the man is on a distinguished road
Re: Bridge building help!!
Diagrams are with the rules. http://www.usfirst.org/roboticsprogr...ated-documents
Part labeled field drawings.
Every day is a new adventure!!!
Unread 08-01-2012, 10:20
FRC #4070
thank you
Unread 08-01-2012, 10:24
GCentola's Avatar
GCentola GCentola is offline
Strategical Tactitian
AKA: Garrick
no team (SparX)
Rookie Year: 2010
GCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud of
Something else that may be helpful is the "field tour" Of the bridge. It can be found here: http://m.youtube.com/#/watch?desktop...aqqmoLgQ&gl=US
GO SparX on 3!!!!!
Check us out at:
http://www.gosparx.org
http://www.facebook.com/SparX1126
I Love Two Pencil Designs!
Unread 08-01-2012, 10:48
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
bad link.
try this:
http://www.youtube.com/watch?NR=1&fe...&v=-AMaqqmoLgQ
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
Unread 08-01-2012, 12:34
GCentola's Avatar
AKA: Garrick
no team (SparX)
Rookie Year: 2010
Originally Posted by ratdude747 View Post
Sorry about that...This is what happens when I post from my Ipod
GO SparX on 3!!!!!
Check us out at:
Unread 08-01-2012, 12:51
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Rookie Year: 2010
slijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to behold
Rather, take a look at Team Drawings - those are boiled-down, simple replicas of the actual bridge that serve as functional replacements that teams can more easily build.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 08-01-2012, 12:58
lbarger's Avatar
lbarger lbarger is offline
Senior LRI NC District
AKA: Lee Barger
FRC #0587 (The Hedgehogs)
lbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud of
I have an issue with the low cost version of the bridge as supplied by FIRST. I have already contacted them about it ans supposedly the information was forward to their engineering team.
The main issue is the deck of the bridge is supported only by 4 3/4" wide ribs all in the same plane. As long as the bridge experience loads in the vertical direction or along it's length that is fine. By if it sides a strong side load (unsupervised hyperactive students or mentors) there is very little to keep the four ribs from simply folding over. For our kickoff event we added blocking between the outer and inner ribs. This took the form of a 6x15" piece of plywood that we attached between two vertical ribs, the top deck and the 2x4 on the bottom.
Also, I believe the plans call for the deck to be attached to the ribs using glue and staples. Use screws instead the staples. After a day of use at our kickoff volunteers were helping to pack up the field. Grabbing the first one by the deck (and not the underlying ribs) the volunteer promptly lifted the deck and left the rest of the structure sitting in place.
