Go to Post No matter what the weight limit is, a large number of teams will *ALWAYS* have trouble making it. - Cory [more]
Unread 08-01-2012, 13:29
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
Rookie Kit Bot Build - Window 7 Activation
How do we activate the Window 7 image being loaded onto the Classmate?
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 08-01-2012, 13:55
cjlane1138 cjlane1138 is offline
Team 1138
FRC #1138 (Eagle Engineering)
Team Role: Leadership
Rookie Year: 2010
cjlane1138 is an unknown quantity at this point
Re: Rookie Kit Bot Build - Window 7 Activation
Once you connect your classmate to the Internet, just let it run its course, make sure you select the option that has to do with Internet Connection...
-Eagle Engineering 1138
Unread 08-01-2012, 18:54
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
Rookie Year: 2012
shuhao is an unknown quantity at this point
Is it just our classmate PC, or does it not come with Windows 7 Pre installed?
Also, the laptop is having trouble recognizing the installer USB key.
Unread 08-01-2012, 19:12
Team 1138
Rookie Year: 2010
Make sure you do not set the boot priority to the USB first, the HDD should be first. When you enter the 2Go boot screen, just hit the F12/F11 key and select the USB. Then let it run its course.
