| View Poll Results: Bridge or Bump? | |||
| Bridge |
54 | 24.32% |
| Bump |
168 | 75.68% |
| Voters: 222. You may not vote on this poll | |||
Re: Bump or bridge?
If your design can cross the bump, then you will never be forced to cross the bridge.
As a competitor in the 2001 competition with a similar bridge, I can tell you going over that WILL take you longer than you think, and WILL tip more robots than you think it will. Also, tipping the bridge down so that you can initially get onto it will not be a trivial task for most teams, and will take a significant amount of time. Do not forget that the bridge does not stay down and must be lowered before you can begin to traverse it. If you doubt me, look up some game video from 2001 and see how bad it can be, that year there were no apposing alliance, everyone was working together as one time and still some robots never traversed the bridge. |
Re: Bump or bridge?
I want to do both why isn't that a poll question.
Re: Bump or bridge?
Go run game simulations and remember the lesson of Breakaway. You are maximally efficient at scoring when you reduce time spent traveling to a minimum. It seems to me like many people on CD are vastly overestimating the number of times a given robot will need to cross the field to be effective. Go look at the name of the game...
Basically, we think that there will be next to no bridge traffic among alliances that are good at playing Rebound Rumble. Designing a robot to cross the bump adds additional design constraints for both your intake and your drive, and saves you... not that much time. The decision you have to make is whether or not the fairly small amount of extra time is worth designing an intake and drive to cross the bump. |
Re: Bump or bridge?
5 Weeks and 4 Days 'till Stop Work Day. Good luck Ladies and Gentlebots. |
Re: Bump or bridge?
Even if you save 4 or 5 seconds, and you only cross 2 or 3 times in a match, thats saves you around 12 seconds. That could be over 10% of the entire match. The tradeoff everyone will need to make a decision on, is that time worth saving by complicating other aspects of your design? -Brando |
Re: Bump or bridge?
to be honest both would be good for flexablity
Re: Bump or bridge?
FWIW, we're designing a robot to be good at either scoring from our key or clearing (i.e. launching) balls from the alley to our side. We decided NOT to build a robot that would often traverse the field. It seems like the ability to control the balls will be a dominate factor for the main game.
KC |
Re: Bump or bridge?
I think it's going to be less important in elims to be able to cross the bump. The strategy that I envision being played out doesn't involve any crossing of the sides more than once, though that requires coordinated and fully functional alliances.
That said, it's not too hard to make a frame capable of crossing the bump anyway without sacrificing much, if anything. One of our ideas was two powered wheels on two supports connected at an angle. The idea is that you have a sensor rotate the wheels, and if done perfectly, you would barely even notice the bump. Switch them fast enough and you might even be able to drive full speed right through it, as if nothing even happened. Just an idea. http://gyazo.com/3bc93bbb13c500e9f7b...png?1326347340 |
Re: Bump or bridge?
We are doing the bump
#10
Re: Bump or bridge?
Here, one might have to take multiple trips back and forth in order to retrieve balls. That is, of course, if long range feeder/shooter bots don't become a norm. But I suppose it's only speculation at the moment. I'll say better to be safe and be able to do both. - Sunny G. |
#11
Re: Bump or bridge?
The bridge is a safe-haven from defending/opposing robots. As long as you are traversing the bridge of your color, your robot is "completely protected" from any defensive or opposing robots. One side of the bridge leads to your alley, which is also "safe" from opposing robot interaction (unless the opposing robot wants to get fouled). These are guaranteed by rules G28 and G25.
I could not say the same for the bump. A good defensive robot could theoretically pin you anywhere near or on the bump, which causes problems. |
#12
Re: Bump or bridge?
Simply put, if your only option is the bridge, you are stuck with the bridge. But, if our system can do both, you don't have to worry about it, and can surprise the competitors. Most systems to cross the bump can also be made to cross the bridge. Just do both.
#13
Re: Bump or bridge?
Both. Even if you can get over the bridge swiftly and smoothly every time, another robot can fall off and block it or take half the match to negotiate it.
Wetzel |
#14
Re: Bump or bridge?
we didnt either
#15
Re: Bump or bridge?
Remember 469? Try your hardest. It's still week 1, anything is possible. |
