Go to Post Doctor the drill, or doctor your hand. Easy choice. Let's all make the right one. - Molten [more]
Unread 08-01-2012, 23:10
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Re: How many of you are actually being a feeder bot?
We haven't decided yet, but my opinion is that your feeding mechanism should be your plan B if your scoring isn't working out. You can always feed if you have a method of shooting balls. If your feeding system doesn't work out, you have nothing.
Unread 08-01-2012, 23:15
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
That is what the other side's argument is, but IMHO. To have a shooter, we would be investing so much time and weight into it. For a feeder, the only actuation you need of the shooter is the yaw. But for the actual shooter, you need both the yaw and pitch. Is that extra weight worth it if we will just go feed? Is the extra time getting the imaging system and everything worth it if the shooter is only that accurate? I would rather have spent my time perfecting the balance (and apparently, the robot does NOT need to be fully supported, will have to ask GDC about that) and have 3 robots balance. Also, because of the simplicity, the feeder mechanism will not break as much as a fully actuated shooter.
Originally Posted by MohammadAdib View Post
My team (not necessarily me) is thinking of a robot that is purely defensive. They assumed that most of the robots are going to be offenders and hence went with a design where the balls are caught in a net and then somehow are thrown back to our alliance robots...definitely not the best idea, i agree
Keep in mind that your strategy opens you up to a lot of penalties. The opposing robot only needs to TOUCH its safezone and touch you. There is a penalty right there. But eventually, the opposing team might get DQ for intentionally doing that.
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 08-01-2012, 23:50
RegaCaska RegaCaska is offline
FRC #0930
RegaCaska is an unknown quantity at this point
That's only true if your close to your opponents safe zones. If you are by the fender, you should be far away enough from the key to be safe from [G28].
