Go to Post The great thing about FIRST is that there actually are 3,000 ways to win. Find yours, and leverage it. - Siri [more]
Unread 08-01-2012, 22:25
shank948 shank948 is offline
VP of Programming - 948
AKA: Stephen Shank
FRC #0948 (NRG (Newport Robotics Group))
shank948 is an unknown quantity at this point
How to Program Swerve in Java
I currently don't have access to wpi library. In the 2012 RobotDrive class, is the swerve drive method designed to be used with one motor for each wheel?
Unread 08-01-2012, 22:27
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: How to Program Swerve in Java
I'm sorry I do not have a programming answer for you, but yet a design question. Do you have any prior swerve experience in both construction and programming?
Unread 08-01-2012, 22:28
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
There is no swerve drive class. You have to write it yourself. Mr. Ether has a great white paper on it. http://www.chiefdelphi.com/media/papers/2426
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 08-01-2012, 22:30
AKA: Stephen Shank
I've been programming on the team for the past two years, but I have a basic understanding of construction. What's your question?
Unread 08-01-2012, 22:32
AKA: Stephen Shank
Wow thanks. I could program it, but I was wondering if there was an easy way. This will be a great help.
