| View Poll Results: What are you programming in? | |||
| Java |
65 | 37.79% |
| C++ |
48 | 27.91% |
| LabView |
56 | 32.56% |
| Other (IDK what you could possibly be doing...) |
3 | 1.74% |
| Voters: 172. You may not vote on this poll | |||
Proprietary programming language that requires an IDE...
Can't really get on board with that. |
Re: What are you programming in?
C++, always have always will
We are using java. it is light weight. After the download fiasco with lab view last year we want our code to be as clean as possible.
We willl be doing Python again! Granted it does help to help to have the developer as my main Programming mentor.
And it should be fairly up to date. I know Peter was spending a lot of the time during the beta test correcting a ton of bugs he found in the provided C++ code when porting/wrapping it for python |
I'd consider myself a fairly experienced programmer, so I'd love to use something like Java.
...But my team uses LabView, and I'm going to be too old to be a team member next year, so I guess it's better to just use LabView :/ Last edited by DallonF : 10-01-2012 at 16:50. |
We use C++ because it gives you more control, plus its a great language!
This is my first year in robotics but i have taken several programming classes before. We are using java because it is the language we feel most comfortable with.
We use JAVA, our team knows it best, our AP class teaches it. And for the most part all 3 do the same job.
However the vision tracking in JAVA is leaving more to be desired. |
#10
While I agree that C/C++ are great languages, I disagree with you on this point.
Just because the LV way of doing something might be different dosen't mean it's impossible or even very hard to do. Having worked with both C and LabVIEW, there are many things which are much harder in LabVIEW if you try to program it like C (in a procedural or object-oriented way). There are some things which are still harder in LabVIEW. However, there are some things in LabVIEW which are harder in C++. It's all a tradeoff. Both languages are fully capable of handling what we are throwing at them. |
#11
It seems that most of the code examples are provided in Labview before any of the other languages.
this is probably due to NI's involvement in labview (which they made), and their support/sponsorship of FIRST
#14
Our team is programming in C++! I'm surprised the majority of people are programming in Java. Then again in most schools there is a few classes for Java.
