Go to Post Do you guys mind if we postpone kick-off to around January 26 or so? We can still keep the ship date on February 20, if that isn't a problem. - dlavery [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 09-01-2012, 14:36
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Re: Poly Cord
Originally Posted by Drivencrazy View Post
What OD's did you guys use in the hollow and solid applications? I would think somewhere around 1/4" would be sufficient but then again I've never used them before.
Yeah 1/4" is what we used. It's the standard cheap yet effective stuff you can get from McMaster and other places
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 09-01-2012, 14:56
RoboCat2005 RoboCat2005 is offline
AKA: Catlin Level
FRC #3659 (Mighty Patriots)
RoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to all
Re: Poly Cord
Are there advantages/disadvantages to using solid as opposed to hollow tubing or vise versa?
Unread 09-01-2012, 15:02
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
Team Role: Teacher
Rookie Year: 1999
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Re: Poly Cord
Speaking as someone who was on a team which had little trouble with the solid core, I think the hollow core with connectors is the way to go.
1. Easier to work with at competition (don't need heat source)
2. Less time consuming (no waiting for cooling)
We used the solid core largely because we had some, tried and it worked. So we had no reason to try the hollow. I have no idea if one of the two variations is more robust than the other.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 11-01-2012, 08:51
JellyMan JellyMan is offline
Mentor, Team 3414
AKA: Jeff
FRC #3414 (Falcon Robotics)
Rookie Year: 2010
JellyMan has a spectacular aura aboutJellyMan has a spectacular aura about
Re: Poly Cord
Thanks everyone for the info concerning the "polycord". I will be placing an order for the 1/4" hollow Urethane Round Belting and barbed connectors.
Two more questions:
1) These round belts in are normally used multiple loops. So, are you machining custom rollers with multiple grooves, or are you stacking off-the-shelf pulleys? Is there a material of choice for the rollers. I suppose aluminum, UHMW polyethylene, or even wood could be used.
2) If we use the barbed connectors, are these actually reliable? Has anyone tried melting the ends in addition to the connectors? Is this overkill?
