Go to Post Honestly, I can't understand why anyone wouldn't want to be a mentor. The fools don't know what they are missing. - Steven Smith [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 20-01-2012, 07:50
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Re: pneumatics or motors?
Originally Posted by DavisDad View Post
The 10 CFM fills an accumulator (reservoir) until charged to about 2-3 PSI. The compressed air is released directly into the end of the cannon; like a potato cannon. The air is released very fast and the 2 psi acts against the 50 sq.in. surface of the ball = 100 lb force at initial release. My calcs say I need about 15 ft-lb energy to accelerate the ball to about 31 ft/sec. The size of the accumulator will determine the final exit pressure on the ball. Of course leakage around the ball is a big variable.
Ah, I misunderstood.
I still think that you should check to see if the valve/hoses will flow enough air fast enough to do what you want. Though I'm still not convinced that an air-cannon is legal.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
  #32   Spotlight this post!
Unread 20-01-2012, 08:52
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
Originally Posted by Daniel_LaFleur View Post
Neither of you are thinking outside the box
Take a 12" cylindar. lock it 1/2 way (mechanical lock like a fence latch). pressurize the cylindar. release the lock and see how fast the cylindar reacts and how far you shoot the ball.
oh, I'd put a hard stop on the rod so you dont damage the cylinders end cap
that plus if you use 4 1/2 inch cylinders vs 1 2 inch cylinder you have the same force but 4 times the flow. when you need speed and force in pneumatics use multiple small cylinders in parallel. and using a mechanical stop to allow the cylinders to charge like daniel said makes a huge difference.
here is a example of a multiple cylinder launcher.
http://www.youtube.com/watch?v=QeQSGmFnKAE
here is another example
http://www.youtube.com/watch?v=0c6mym04OGs
both of those shooters used multiple cylinders with a mechanical stop the breakaway bot used a door latch type mechanism and the overdrve bot had a delta p of about 1.5 psi so the pistons would deform into the ball until there was enough force to break the vacuum.
which with that amount of surface area was about 200-300 pounds
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014-2016
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
  #33   Spotlight this post!
Unread 20-01-2012, 09:31
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
OK. Lets go through this:
1: How do you charge the accumulator without using a valve(0.32CV) between the accumulator and the cannon?
2: In order to release the air that fast you would need either a vane valve or sprinkler valve. Both have CVs too high for FIRST.
3: Consider your mass flow. As the valve is opened the air starts to flow and pressure begins to build in the cannon (I'll ignore leakage around the ball, which you'd want to lower frictional forces). When the pressure gets to ~0.15PSI (12 oz acting on an 11 oz ball) the ball will start to move up the cannon.
4: Pressure will remain ~ 0.15PSI as the air fills the, now additional, volume created by the ball movement. giving you only .75LBf of the 15LBf that you need.
My guess is that the ball never leaves the cannon, as the leakage around the ball will probably have a higher CV than the CV of the valve used.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
  #34   Spotlight this post!
Unread 21-01-2012, 08:07
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
Rookie Year: 2012
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Originally Posted by Al Skierkiewicz View Post
The valve you would need to release that pressure still would need to be higher than 0.32cv (not 0.35) correct? ...
1: How do you charge the accumulator without using a valve(0.32CV) between the accumulator and the cannon? ....
Good point, but the release mechanism isn't a solenoid and would have to be exempt form the Cv limitation. Maybe low pressure systems (< 5 PSI) won't be considered "compressed air" rather "high energy fan system".
I'm also thinking of charging the cannon directly by the blower (no reservoir) and just tuning the blower ON/OFF. Modulation of the force would be done by varying the voltage on the blower motor.
At any rate, I'll be protoyping this today and let you know if the performance makes it worth pursuing.
  #35   Spotlight this post!
Unread 23-01-2012, 07:37
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Dad,
Unfortunately, any pneumatics are inspected under the pneumatics rules regardless the pressure. Blowers on the other hand will be looked at for electrical, motor, mechanical and safety parts of the inspection checklist. Of particular concern would be exposed moving parts. They are pretty much handled the way ball launchers would be. We don't want fingers getting damaged or worse so things do need shields when they pose a threat to humans.
Al
WB9UVJ
www.wildstang.org
________________________
  #36   Spotlight this post!
Unread 23-01-2012, 09:19
DavisDad's Avatar
MechE
Rookie Year: 2012
Dad,
Unfortunately, any pneumatics are inspected under the pneumatics rules regardless the pressure. ...
Hi Al,
Thanks so much for the clarification. This makes sense as any stored energy from CA is a potential danger and following a standard CA safety standard is required.
Much appreciated,
Craig
