Go to Post I didn't say this! - Max Lobovsky [more]
Unread 09-01-2012, 20:55
eulerddx4
Posts: n/a
Can't Install Windriver
Hello, I have a mac and am using VMware w/ windows 7. I know that Professor Miller uses this configuration so in theory I should have no problem. For some reason when I put in the disk and click setup.exe as it pops up - the disc spins and then I get "An error has occured. See the log file \\ vmware - host\ shared Folders\ .wrinstaller -1.2 \1326159933097.log
I am using disc one that came in the kop
Thanks,
JP
Unread 09-01-2012, 22:29
eulerddx4
Posts: n/a
Re: Can't Install Windriver
So, I put in disc two and that is working... It says install disc 1 first. Is it bad to install disc 2? I'm using windows 7
Unread 09-01-2012, 22:31
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
I've been using Parallels, and I'm not sure if the difference is the issue. That message is a new one on me.
Is that an out of the box Windows 7 installation? Have you successfully installed other stuff on it?
Brad
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 09-01-2012, 23:17
eulerddx4
Posts: n/a
Hello, Thanks for the reply! I actually just purchased this copy of windows and have installed solidworks.
Unread 09-01-2012, 23:19
eulerddx4
Posts: n/a
Using disk two only made me think it was working! It got to 47 % and gave me a similar error message...
Unread 10-01-2012, 00:58
eulerddx4
Posts: n/a
Case Solved! As Professor Miller hinted, there is some problem with VMware fusion. If you are on a mac and trying to use windows for coding in wind river either use boot camp or parallels. I am using parallels and it works perfect.
Thanks,
JP
