Go to Post What if, each alliance has a pile of AndyMark equipment in front of them. They then have 2:00 minutes to assemble said equipment, and build a working robot that will race to the other side and grab the other alliance's flag. - Pjohn1959 [more]
Unread 01-09-2012, 10:45 PM
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
There's a new version of the Cookbook posted
There is a new version of the Robot Programming Cookbook posted on the WPILib project under the documents section. It has a new section on writing command-based programs in C++ with a fairly extensive tutorial. I would highly encourage teams using C++ to check it out. It makes writing complex robot programs much simpler and provides a "cookbook" method of organizing your code.
http://firstforge.wpi.edu/sf/docman/..._documentation
I still have to add more C++ examples to go with the existing Java code, but this should make it a lot better for everyone thinking about using this approach to programming your robot.
Brad
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
