Go to Post STEM: Science, Trial, Error, Math. - hrench [more]
Unread 10-01-2012, 07:48
jcarm's Avatar
jcarm jcarm is offline
AKA: Jeff Carminati
FRC #3044 (OxBE4)
Team Role: Mechanical
jcarm is an unknown quantity at this point
6 Wheel Tank Drive or Just Stait up Tank Tread?
Alright my team is thinking about using either are original 6 wheel tank drive or we are thinking about using tank tread, so any any opinions, info, and possible places to get matterial or acually treads would be helpful.
Thanks
Unread 10-01-2012, 08:04
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
Re: 6 Wheel Tank Drive or Just Stait up Tank Tread?
We are having the same thoughts. Though, our decision would be 6 wheel tank drive or 4 wheel skid. (Same thing, only 4 wheels) 6 wheels would be easier to move around though going over the bump in the center leaves us in more danger of flipping. We have thought of ways around it though we have decided to go a route in which we can do either. A switch between 4 wheel and 6 wheel in 20 minutes or less.
Unread 10-01-2012, 08:07
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
Run a few searches and you find a lot of info on tank treads here on CD. Brecoflex was a popular manufacturer used by several teams a few years ago.
2011 Championship Finalists/Archimedes Division Championships w/ 2016 & 781
2010 Championship Winners/Newton Division Champions
Thank-you 294 & 67
2009 Newton Division Champions w/ 1507 & 121
2008 Archimedes Division Champions w/ 1124 & 1024
2007 Championship Winners/Newton Division Champions w/190, 987 & 177 The Wall of Maroon
2006 Galileo Division Champions w/ 1126 & 201
www.bobcatrobotics.org
"If you can't do it with brains, it won't be done with hours." - Clarence "Kelly" Johnson
Unread 10-01-2012, 08:32
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
Really comes down to your design constraints and resources at hand. A few teams ran systems by outback a two years ago with much success.
http://www.chiefdelphi.com/media/photos/35293
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 10-01-2012, 08:42
s.west2960 s.west2960 is offline
FRC #2960
s.west2960 is an unknown quantity at this point
Our team used a tank tread one year and we kept stripping off our drive chains, so we also had it set up to where we could take off the treads and quickly and easily put wheels onto it, also a good idea might be a halftrack which is two wheels in the front and short treads in the back, link related, its a halftrack
http://www.antiaircraft.org/aaimages/M16.jpg
Unread 10-01-2012, 09:00
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Tank treads can be cool but there are difficulties associated with them. I would recommend they not be attempted durring build season without previous experience. Save them for an off season project.
Unread 10-01-2012, 09:08
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
This x1000. Drive train experimentation should whenever possible be limited to the offseason, unless you're extremely confident you have the resources and know-how to pull it off.
Tank drives are notorious for an inability to turn due to insufficient torque. This can be overcome, but it's not trivial.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 10-01-2012, 09:19
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
Rookie Year: 2011
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
i would say go for 6 wheel tank drive over tank tread because with the treads would be difficult to go fast and the treads could get stuck on the hump (if your going over it)
high school sophomore, second year mechanical
Unread 10-01-2012, 09:32
Benjdragon Benjdragon is offline
None #1985
Benjdragon is an unknown quantity at this point
If you are trying to get 3 robots on a bridge, the having 6 wheels might allow you to have two wheels hanging over the edge and be able to stay on the bridge. Being to turn sideways on the bridge would help also.
Unread 10-01-2012, 09:46
Tazlikesrobots's Avatar
Tazlikesrobots Tazlikesrobots is offline
Jack of all trades...Master of none
AKA: Robert
FRC #1745 (P-51 Mustangs)
Team Role: Coach
Rookie Year: 2000
Tazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud of
Send a message via Yahoo to Tazlikesrobots
I'd recommend 6 wheels. Tank treads do not take side loads very well...
It is all mind over matter....If you don't mind, it does not matter.
_________________
2006 Woodie Flowers Award Recipient - Lone Star Regional
2006 Rookie All-Star - Lone Star Regional
2007 Lone Star Regional Champions
2008 Quarter-finalist - Lone Star Regional
2009 Chairman's Award & Website Award - Dallas Regional
2009 Quarter-finalist - Dallas Regional
2010 - Xerox Creativity Award & Semi-finalist - Dallas Regional
Unread 10-01-2012, 10:22
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
Team Role: Teacher
Rookie Year: 2011
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
I'm pushing my kids towards wide-frame 4-wheel skid, probably 8" wheels with a little lift. Though about tank tread, but lack of experience is holding me back.
Unread 10-01-2012, 10:31
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Stright tank tread =).
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Unread 10-01-2012, 16:12
bf2416's Avatar
bf2416 bf2416 is offline
AKA: Blake Frasur
FRC #4058 (Boombots)
Rookie Year: 2012
bf2416 is an unknown quantity at this point
Just curious, we weren't sure if there was anything in the rules requiring that wheels be used, or are tracks allowed within the rules
Part of our design was hinging on the availability of tracks just making sure we didn't miss something in the rules
Thanks for the help
Unread 10-01-2012, 16:52
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Thanks for the help
When it comes to what kinds of wheels, treads, etc. you use FRC does not restrict what you can use beyond the size, weight, and price restrictions that apply to the entire design. Generally this is true for any materials on the robot other than pneumatics, electrical systems, and certain sensors. However, when looking to do something entirely new for your drive train in the build season, keep in mind that if your robot doesn't move well, it won't do much else well (unless you've built around a strategy that doesn't require mobility). If you choose to do something new, proceed with caution.
[2016-present] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
  #15   Spotlight this post!
Unread 10-01-2012, 18:18
bf2416's Avatar
AKA: Blake Frasur
Rookie Year: 2012
All right thanks for the feed back. I think that our team has decided not to use treads, but the response was much appreciated
