Go to Post I don't mean to sound harsh, but I do not want you to get your hopes up. There are deadlines in FIRST. - RoboMom [more]
Unread 10-01-2012, 19:19
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Mounting compatability
From what I've seen, the Banebots RS-550, AM-9012, and FP (specifically the 0673) are all advertised as BB 500-size motors. Does this make their mounting configuration identical to each other, so that any gearbox advertised from AndyMark or Banebots or another supplier to fit one of these motors able to fit any of these that we would want to hook up?
Attending: MN Duluth Regional
Unread 10-01-2012, 19:24
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: Mounting compatability
I know the FP can mount to a 550 gearbox, as long as you trim the shaft a little bit.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 10-01-2012, 21:49
DonRotolo's Avatar
Back to humble
FRC #0832
Go to the BaneBots website, motor section. If all the motors you have will mount to the same BaneBots gear boxes, they must be the same, no?
