Go to Post Though, of course, if the old one you like is shot, then you can just beat your new one with a hammer until it works the way you want. - Kevin Sevcik [more]
Unread 10-01-2012, 21:06
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
Team Role: Leadership
Rookie Year: 2010
baronep is on a distinguished road
Accelerometer Example on New Crio
Does anyone know if the ADXL345 SPI example works on the new Crio? I tried to run it and it gave me an error along the lines of 'I can't find DIO module 2' Any ideas?
Unread 10-01-2012, 23:09
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Accelerometer Example of New Crio
The obvious question is: do you actually have a second DIO module installed in your cRIO? It would go in slot 4 of a 4-slot cRIO-II, or slot 6 of an 8-slot cRIO.
The first DIO module is number 1, even though it's actually installed in slot 2. That's a different way of numbering things from previous years, and I expect it'll trip up a few teams.
Unread 10-01-2012, 23:20
baronep's Avatar
Student President
Rookie Year: 2010
That is what i suspected as well, so I added a control to select crio slot (which defaulted to DIO2 BTW) and changed it to 1 but i received the same error. I know thats not a lot to go on, I will do some more investigative work tomorrow afternoon (how does school always seem to get in the way).
Unread 11-01-2012, 03:22
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
You selected Digital Module 1 and still got an error that said you have no Digital Module 2? Maybe you didn't actually change the value. Did you make it a control on the panel of a VI and then deploy it? Did you re-build?
-Joe
Unread 11-01-2012, 08:15
Software Architect
...I added a control to select crio slot (which defaulted to DIO2 BTW)...
"DIO2" sounds like a pin number, not a module number. You might have wired the control up to the wrong terminal on the Open function.
Unread 11-01-2012, 09:16
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
What Joe said to do should work - wire a control to the DIO Module terminal and set it to Digital Module 1. It looks to me like we have a "bug" in our example. By default the ADXL345 SPI Open.vi should have Digital Module 1 as default. We should probably also wire and show that on the example front panel. I will fix this.
Doug Norman
Unread 11-01-2012, 12:36
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Sorry if this has been covered elsewhere, I could not find the info we are looking for and I am not versed enough in LabView to figure it out.....yet.
We can figure out how to run the I2C ADXL345 example, but where we are struggling is how to go about integrating the vi's into our robot project.
As far as we can see, the vi's to add the ADXL345 I2C are not available anywhere in the Functions pallet.
Can someone please point us in the right direction to help us figure out how to add support for the ADXL345 via I2C to our project?
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 11-01-2012, 14:54
baronep's Avatar
Student President
Rookie Year: 2010
In the project explorer in the example project, there is a folder called ADXL driver. Just copy these VI's to your robot project
Unread 11-01-2012, 17:39
NeatNit's Avatar
NeatNit NeatNit is offline
Alumni Programmer
FRC #1577 (Steampunk)
Team Role: Teacher
Rookie Year: 2011
NeatNit is an unknown quantity at this point
I've spent half of yesterday and all of today trying to get the ADXL345 working. I've tried both examples using two cRIOs, and nothing works. I did change the DIO module constant/control to 1 instead of 2. I did make sure the sensor is wired correctly. I see no reason why it wouldn't be working.
I posted my question here after somehow missing this thread.
Please help!
Unread 12-01-2012, 15:59
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
There's updated files for the SPI ADXL345 example attached to the firstforge bug report. http://firstforge.wpi.edu/sf/go/artf1432
Unread 20-01-2012, 16:21
NeatNit's Avatar
Alumni Programmer
Team Role: Teacher
Rookie Year: 2011
The fixed SPI example still doesn't work for me. I've finally gotten I2C working though, apparently it only works with the flat cable.
Unread 20-01-2012, 16:28
Rookie Year: 1997
Not sure what "flat cable" you are talking about. If it is the DB-37 cable from the kit, then it "only works" if you fix the cable end to not be reversed.
Unread 20-01-2012, 16:31
NeatNit's Avatar
Alumni Programmer
Team Role: Teacher
Rookie Year: 2011
Yes, I meant that flat cable the replaced the thick round ones in previous years. What I meant to say is that the ADXL345 doesn't work with the old cable, in other words only works with the newer flat one. (our cable needed to be flipped but we already did that)
Unread 20-01-2012, 16:33
Rookie Year: 1997
It works with my thick round one. Maybe yours is just damaged.
-Joe
  #15   Spotlight this post!
Unread 20-01-2012, 16:37
NeatNit's Avatar
Alumni Programmer
Team Role: Teacher
Rookie Year: 2011
-Joe
Taken from this thread: http://www.chiefdelphi.com/forums/sh...d.php?t=100324
Originally Posted by ggorsuch View Post
Got it working!
Used the flat db37 cable included in this years Kop, instead of the old round one.
Originally Posted by abrightwell View Post
That's what we just did and sure enough it worked. Makes sense as when we Ohm'ed it out, pin 1 went to pin 15 on the other end. I didn't think to check the KoP website, but I'm definitely going to check it out. It still seems like a curious situation that the flat works for the accelerometer but the round doesn't. :-/ Oh well, I'll take it at face value for now.
Thanks for the follow up!
Sure, these are Java, but I'm still seeing a recurring pattern....
