Go to Post Ice cream is an iterative process. - JVN [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 17-01-2012, 19:35
zkxs's Avatar
zkxs zkxs is offline
Java Programmer / Electronics
AKA: Michael
FRC #2004 (Thunderducks)
Rookie Year: 2010
zkxs is an unknown quantity at this point
Re: Problem installed FRC Plugin on Netbeans
I checked, and the XP laptop that a NetBeans reinstall fixed had 4GB RAM.
Originally Posted by rudun
Deleting the sunspot folder and installing the plugins manually worked for me.
I tried a manual install first, and I can't find a sunspot folder. Do these plugins expect to be able to install to a shared directory? I'm not running Ubuntu as root, so NetBeans doesn't have privileges to write to shared directories.
Unread 17-01-2012, 21:02
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Okay, same problem... We are using a server with 3 gigs of Ram and Xeon processors, NOT the issue here. So I had issues with my personal laptop, but somehow it eventually installed... I tried both manual and the automatic update one. So it shows up as installed until I restart the IDE. Then it has no evidence that it even installed. Tried it 10 + times both manually and automatically... I know what Einstein said about repeating the same thing over and over again...
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 18-01-2012, 18:24
Secretspy97 Secretspy97 is offline
FRC #1126
Secretspy97 is an unknown quantity at this point
We resolved our problem by installing the newest version of NetBeans and then installing the FRC plugins.
