Sample project templates don't match "Getting Started"
Hi all,
I have installed Wind River 3.3 on a computer and have installed the 2012 Workbench update provided here: http://firstforge.wpi.edu/sf/frs/do/...CDBAA526D850D5 In the "Getting Started with the 2012 FRC Control System" pdf file here: http://www.usfirst.org/sites/default...20System_2.pdf on page 22 it shows which example/base programs should be available. However, the choices that Wind River provides me are not the same and seem to be from the 2009-2010 era: ![]() When I create a new FRC Default Program, for example, the beginning documentation is the same as that from Team 67's 2010 robot code, and references the 2009 FRC Manual. Is this correct? If not, how do I fix this problem? I've installed Wind River on a new computer that had no previous installations of Wind River. How much has the default code changed since 2009/2010? Last edited by JABot67 : 11-01-2012 at 17:04. Reason: Fixed link |
Re: Sample project templates don't match "Getting Started"
I am having the exact same problem. Any solution/leads thus far?
You have the Kinect examples there so you have the right installation (the Kinect is new this year). The documentation seems a little out of date.
