Go to Post As part of this test phase, I would expect to see Aidan sleeping on the job for most of the upcoming season. :) - dlavery [more]
Unread 11-01-2012, 21:35
duffany1 duffany1 is offline
AKA: Brandon
FRC #0195 (The Cyberknights)
duffany1 is an unknown quantity at this point
Vision Camera: C++ Implementation?
Hello,
We are trying to figure out how to implement the vision camera in our C++ code.
We have discovered that the NI Vision Assistant, which can get you the binary image, allows you to export C code. But, our question is, how do we implement this with C++/Windriver/WPI Library? The exported C code isn't very clear to us. Does anybody have any insight into this matter?
Unread 11-01-2012, 21:42
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Vision Camera: C++ Implementation?
Originally Posted by duffany1 View Post
Hello,
The code generated calls directly to the IMAQ libraries (which are the backend of the WPILib code you see). To use it, after getting the image, you can say
Code:
IVA_ProcessImage(m_image->GetImaqImage());
You'll want to also grab the results of the final step in your script from the generated code. How you do that depends on the exact script you're generating.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
