Go to Post Don’t choose to aim for the stars because they mark the peak of our abilities, don’t choose to aim for the stars because it is easy, choose to aim for the stars because it shows the depth of our potential; choose to aim for the stars because it is hard! - Ken Leung [more]
Unread 12-01-2012, 00:01
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
Team Role: Leadership
Rookie Year: 2010
baronep is on a distinguished road
Tachometer using Retro-Reflective sensor
I saw this used in one of the FIRST robotics books and I was wondering specifically how someone would implement this?
Unread 12-01-2012, 00:29
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Tachometer using Retro-Reflective sensor
The tape is placed on a rotating object in segments. This allows a photo sensor aimed at the tape to alternately turn on and off at the segment rate effectively counting segments. Say there are eight transitions on a 6" diameter wheel, you might be able to resolve horizontal movement of the robot on the order of less than one inch per segment. More transitions gives you better accuracy. If you use two sensors you can actually determine direction as well as rotation distance.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 12-01-2012, 00:31
baronep's Avatar
Student President
Rookie Year: 2010
Ok. I was more interested in sensing speed rather than distance. Does anyone know how to implement the code for this? Is DMA involved? Periodic tasks? Interrupts?
Unread 12-01-2012, 00:35
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
It should be simple using the counter vis.
Unread 12-01-2012, 10:02
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
There's an example towards the bottom of the page here: http://team358.org/files/programming...2009-/LabVIEW/
Search fot "Tach"
