Go to Post If you see Navy ships in port, you're going to be fine. If you see ships pulling out, or no ships at all, go East. Fast. - Matt Howard [more]
Unread 01-12-2012, 04:32 PM
sretter's Avatar
sretter sretter is offline
AKA: Shaked
FRC #2231 (OnyxTronix)
Team Role: Leadership
Rookie Year: 2010
sretter is on a distinguished road
Building error
Hi everyone,
We're having the following error when we try to build the following code to the cRio:
http://imageshack.us/photo/my-images...ileerroru.png/
We have the lastest netbeans, and we imaged the cRio,
Can anyone help?
Thanks,2231
Unread 01-12-2012, 04:53 PM
electriczap4 electriczap4 is offline
FRC #4254
electriczap4 is an unknown quantity at this point
Re: Building error
We just solved this error, we ended up disabling the firewall on the classmate.
It's in the control panel under Security.
Unread 01-13-2012, 01:58 AM
SheMesH SheMesH is offline
FRC #2231
SheMesH is an unknown quantity at this point
Re: Building error
Thank you for your answer.
Do you know which static ip we should put for compile the java files to the controller?
Thanks, team 2231.
Unread 01-13-2012, 04:44 AM
BradAMiller BradAMiller is online now
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
If you are running the Driver Station and dashboard on your development computer, use 10.x.y.6 for your IP address. If the driver station is also on the network, use some IP address not taken by the other parts of the system, like 10.x.y.42.
Brad
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
