Go to Post Guys wearing pink, that strikes fear into my heart now :). - Cyberguy34000 [more]
Unread 12-01-2012, 21:37
mackenzie2085's Avatar
mackenzie2085 mackenzie2085 is offline
FRC #2085
mackenzie2085 is an unknown quantity at this point
2012 pneumatics air capacity
Despite this being an obvious question...has anyone found the rules regarding the max legal air capacity for this years robot? Much appreciated!
Unread 12-01-2012, 21:41
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: 2012 pneumatics air capacity
Yes, I found them. [R71-I].
I don't see any numbers of tanks in that rule...
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 12-01-2012, 22:44
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
There has not been a limit in 2011 or 2012. You still need to satisfy other rules such as $3500 max cost and no more than $400 for a single item, and they are counted in the robot weight. However, the KOP compressor or equivalent can only pump up so much volume in a single match.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 14-01-2012, 14:01
FRC #2085
very helpful, thank you both!
Unread 29-01-2012, 17:48
mehrkam's Avatar
mehrkam mehrkam is offline
Paul Mehrkam
FRC #0836 (Robobees 836)
Rookie Year: 2007
mehrkam is on a distinguished road
In addition to cost, the only thing that we can figure out is that you can only presurize with a compressor powered by the robot even if it is off board <R73>. Therefore you have to run your system between matches to refill the tanks.
Make sure that refill time is less than 5 minutes, because that is the time between matches in the semifinals.
If there is another interpetation of this rule, let me know.
Unread 29-01-2012, 21:26
DonRotolo's Avatar
Back to humble
FRC #0832
There is also a Q&A question and response basically stating there is no explicit limit on the number of storage tanks.
Unread 29-01-2012, 21:52
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Remember to consider the large capacity plastic reservoirs now available. Too bad we still have to use those brass fittings. Or do we?
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 29-01-2012, 22:20
DonRotolo's Avatar
Back to humble
FRC #0832
We do not. As long as they meet the rules, they can be plastic, aluminum, or any other material... (Yes, we do need connectors, just not ones of heavy brass)
[R69] All pneumatic components must be COTS pneumatic devices rated by their manufacturers for working pressure of at least 125psi (with the exception of [R71]-D).
[R71] The only pneumatic system items permitted on 2012 FRC Robots include the items listed below.
<snip>
F. Pressure transducers, pressure gauges, and connecting fittings,
