Go to Post Scout team, assemble! (preliminarily) - PayneTrain [more]
Unread 12-01-2012, 22:48
indubitably's Avatar
indubitably indubitably is offline
AKA: Ryan Guinn
FRC #2338 (Gear It Forward), FRC #1732 (Hilltoppers)
indubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond repute
cRIO Imaging
When we try to image the cRIO using the 2012 imaging software, it simply tells us that it cannot find a connected cRIO. This is confusing because the old imaging software recognizes communication and so does the new driver station. We can also ping 10.xx.yy.2. The 3 updates for utitilites, the driver station, and LabVIEW on NI's website have all been installed.
Any ideas on what the problem may be?
FRC 1732 (Hilltoppers): Mentor
FRC 2338 (Gear It Forward): Mentor/Alumnus
FRC 4096 (CTRL-Z): Mentor
Unread 12-01-2012, 23:00
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Re: cRIO Imaging
Is Windows Firewall (or indeed any firewall) enabled? If so you may have to let the 2012 imaging software through. We had some instances of having to do this, but some where it wasn't necessary.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 12-01-2012, 23:01
AKA: Ryan Guinn
Re: cRIO Imaging
I'm pretty sure we allowed an exception for it, but I suppose I could just turn it off all together.
Unread 13-01-2012, 23:00
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: cRIO Imaging
You should also make sure every other network interface is DISABLED. Don't just turn off the WiFi radio; actually disable the wireless networking in the control panel.
