OCCRA
Go to Post the hardest task this year is the same as every other year: getting the engineers out of the crate so you can close it up and the FedEx guy can haul it away! - KenWittlief [more]
View Poll Results: How are you Levitating?
Not climbing ourselves, but maybe on someone else 24 12.44%
Climbing just ourselves 85 44.04%
Providing ramp for 1 or 2 other robots 31 16.06%
Climbing, lifting 1 or 2 bots with us 53 27.46%
Voters: 193. You may not vote on this poll
Unread 02-12-2018, 11:34 PM
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Rookie Year: 2007
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
Climbing Plans
Now that we're nearing the end of build season, I was wondering what decisions teams have made with their designs in regards to the climbing points/ranking point.
Unread 02-12-2018, 11:56 PM
Keefe2471's Avatar
Keefe2471 Keefe2471 is offline
FRC #2471 (Team Mean Machine)
Keefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud of
Re: Climbing Plans
Even with the "Chief Delphi Bias" this should be pretty interesting. I would think that robots that can facilitate triple climb points will be more common than 40 kPa solo robots were last year, but how common, we will have to see.
Unread 02-13-2018, 12:10 AM
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
Mentor
FRC #4607 (C.I.S.)
Rookie Year: 2012
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
Re: Climbing Plans
The poll should have included: "Not planning on climbing - just working towards levitate in the last 30 seconds".
Minnesota Robotics Coaches Association
Central Minnesota Robotics Hub
FRC 4607, C.I.S.
"Innovation cannot happen in isolation"
Unread 02-13-2018, 12:12 AM
Austin2046's Avatar
Rookie Year: 2007
Re: Climbing Plans
I'm hoping most teams with solo climbers can allow for a 2nd solo climber as well, but maybe they won't. I get the feeling most teams out there will be banking on the Levitate power up or climbing on someone else, but the "Chief Delphi Bias" might skew my poll away from this reality. I really have no idea how many triple climbers there will be, but I get the feeling the 3 climb RP will occur a little more often than the 40kpa RP last year.
Unread 02-13-2018, 12:14 AM
Austin2046's Avatar
Rookie Year: 2007
Re: Climbing Plans
Yeah if I knew how to edit my poll I'd probably change the first option to something like, "using the Levitate power up or using someone else."
Unread 02-13-2018, 12:39 AM
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Climbing Plans
And don't forget to add one:
"Climb ourselves, but will climb on others if possible."
Past teams:
2003-2007: FRC0330 BeachBots; 2008: FRC1135 Shmoebotics; 2012: FRC4046 Schroedinger's Dragons
Unread 02-13-2018, 05:29 AM
Ambroses Ambroses is offline
FRC #4362
Ambroses is an unknown quantity at this point
Re: Climbing Plans
We are implementing what we refer to as a “courtesy climb”. Meaning that we will use less than 50% of the bar (Left or Right) leaving room for another climber that is also courteous. Any others have this idea too?
Unread 02-13-2018, 08:11 AM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Climbing Plans
We are planning to be able to use the square tube if an alliance partner can use another part of the rung. The problem is, we have to be on a specific side....since the climber is on the corner of our robot.
Unread 02-13-2018, 08:52 AM
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: Climbing Plans
Ummm.... where's the "other"?
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 02-13-2018, 08:43 PM
Austin2046's Avatar
Rookie Year: 2007
Re: Climbing Plans
I'm pretty curious as to what other would be... we have not climbing, climbing solo, helping teammates climb, and climbing with teammates... would "other" be helping opponents climb?
Unread 02-13-2018, 09:38 PM
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Rookie Year: 2013
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Re: Climbing Plans
I would add the buddy bar to the poll, if you can climb on the rung you will be able to climb from our buddy bar.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 02-14-2018, 06:46 AM
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Climbing Plans
Ding! Ding! Ding!
Although ours is a bit more than a 'buddy bar'
- Tennyson, Ulysses
Unread 02-14-2018, 07:10 AM
Austin2046's Avatar
Rookie Year: 2007
Re: Climbing Plans
Ding! Ding! Ding!
I suppose I was considering the buddy bar as a subgroup of the climbing just ourselves or the climbing and lifting 1 or 2 other robots group, but yes maybe that should have been a more distinct option in the poll.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
