Go to Post Remember: This is High School Competition. - rich2202 [more]
Go Back   Chief Delphi > CD-Media > White Papers
photos
papers
everything
Controller Circuit- Infrared Emitters
tribotec_ca88
By: tribotec_ca88
New: 11-02-2004 11:07
Updated: 11-02-2004 11:07
Total downloads: 257 times
Tribotec Team Whitepaper
" While initiating tests with the infrared, we realized that a 40 kHz
generator was needed to be adapted into the infrared emitters. But thinking about the adaption of this disposition on the field of tests, we felt it was necessary to develop a similar generator, ...
generator was needed to be adapted into the infrared emitters. But thinking about the adaption of this disposition on the field of tests, we felt it was necessary to develop a similar generator, independent of the one provided in the kit. It was also difficult to simulate the real arena
because from one side the emmiters send the 40 kHz pulses in 1 ms
and from another side it takes 2 ms, which requires a certain control
of the release of the pulses. "
Our whitepaper explains the solution to this problem, and how the solution can be done.
Credits go to Cabeça and Grande
  • zip Controller Circuit- Infrared Emitters
    1076515648controller.zip
    downloaddownload file
    uploaded: 11-02-2004 11:07
    filetype: zip
    filesize: 67.8kb
Recent Downloaders
Discussion
view entire thread
rwaliany
Unread Re: White Paper Discuss: Controller Circuit- Infrared Emitters
I'm kind of confused about the use of this. Ours works fine with no problems. I don't see why you would need to redo anything. We can drive to either beacon fine and do some other stuff which I'm not telling you about :-P.
view entire thread
Tags
loading ...
