1/16 Wall Rounded Corner Aluminum Square Tube?
I am looking for rounded corner aluminum square and rectangular tube in 6061 alloy and thinner than 1/8" wall, such as 1/16" wall thickness. 1"x1" and 1"x2" are the exterior sizes I’m looking for.
The application requires rounded corner tube, so please don’t bother suggesting any alternatives. I know 1" square thin wall rounded corner exists, but I am unable to find a good drawing of what the cross section looks like. McMaster 6546K53 looks close to what I need, but I’m not real sure what the corners look like. I need something with a pretty constant wall thickness, including in the corners. Any other sources?
All aluminum rectangular tubing I’ve every bought from McMaster has right angle corners.
Something like this? https://www.onlinemetals.com/en/buy/rectangle-tube?q=%3Arelevance%3AShape%3ARectangle%2BTube%2BRadius%2BCorner%3AMaterial%3AAluminum&checkbox=on&sort=relevance#
Does it have to be 6061?
Andymark has 1/16" 2x1 tubes with a filleted inside: https://www.andymark.com/products/2x1x0-063-aluminum-box-extrusion-6ft?via=Z2lkOi8vYW5keW1hcmsvV29ya2FyZWE6Ok5hdmlnYXRpb246OlNlYXJjaFJlc3VsdHMvJTdCJTIyYnV0dG9uJTIyJTNBJTIyc2VhcmNoJTIyJTJDJTIycSUyMiUzQSUyMmFsdW1pbnVtJTIyJTJDJTIydXRmOCUyMiUzQSUyMiVFMiU5QyU5MyUyMiU3RA
@Zook I’m looking for thinner wall. .125 wall is readily available. @AdamHeard It’s strongly preferred but I would entertain the thought of other alloys. Do you have a source? @Alejandro_Pina That’s interesting stuff, but what I really need is fillets on the outside corners as well.
8020 has some 1 x 1 https://8020.net/9000.html
One of our sponsors sells rounded corner square tubing for telescoping applications.
https://www.extrude-a-trim.com/aluminum-extrusions/aluminum-tubing/telescopic/11
If you look at the table below, it specifies the inner and outer radius for the various sizes. They don’t specify, but I’m pretty sure the alloy is 6063.
