We are having an odd wireless network issue when trying to replicate an FMS environment in our shop.
First our hardware:
AIR-AP1252AG-A-K9 , the same radio used for FIRST FMS and Cheesy Arena.
OM5P-AC configured with the Radio config tool ver 17.3 in “FMS Lite” mode with bandwidth limiting on.
MS lifecam hd-3000 directly into the RoboRio.
We use static IP’s on our robot and DS. The Cisco is set up simply to be an AP with no QOS. The DS connects directly to the AP’s Gb Ethernet port.
We use the Web cam for live view at 320X240 20fps. This uses less than 2Mb/so.
When we try to run this through the AP, we can only get 1fps video. Robot control is normal although wireless programming is slow, but still works.
Now, if we configure the OM5P-ac in the standard mode for team use, putting it into AP mode, with bandwidth limit on, it works great and we get video and good robot control.
The question is, is anyone else running your shop or practice field with this Cisco AP and can you get video through it at a decent rate?
