With the new control system, the VRM is somewhat obsolete. I’ve been looking for a nice solution to power consumer-grade network switches and other 5 volt devices that isn’t quite as bulky as the VRM. I think I just found the perfect solution: https://powerwerx.com/usbbuddy-powerpole-usb-converter-device-charger
Thoughts on this? Does anyone have other 5v power supplies convenient for FRC?
The specs on that aren’t great for FRC, as it’s quite common for battery voltage to drop well below 10 volts. You should look for a product with as low a minimum voltage as possible—note this will mean looking at buck/boost converters to get below ~7 volts input for a 5 volt output. The VRM for example goes down to 5 volts input.
The CTRE CANdle is a pretty good option for heavier loads: 6A output at 5V, with 6V minimum input.
We ordered this to power our rPi /Coral TPU. Can’t tell you if it is any good as we will be putting it on today. Though I wouldn’t say the VRM is obsolete as it is still good to power 5v under 2amp but the rPi 4 wants 3 amp and it is powering a TPU as well. a VRM should still be good for other 5v applications.
We have been using the “Drok” branded version of this same device this build season to power a rPI 3B+. It’s been solid. We had previously powered the PI with a battery pack to eliminate brownouts, but even with running the robot hard in practice and pushing the batteries further than would seen in a competition round, we haven’t browned out the PI. A buck converter like this would easily power a network switch. As an aside, we are using a good-ol VRM to power our network switch and a couple other small loads and it is doing fine for those roles.
