2 cameras for comp 2019
#21
Sorry I’m not a programming expert but I just thought it would be a way to only use one camera to solve it
#22
Naaah it’s cool.
Thanks for the suggestion though!
#23
You’re welcome
#24
The camera select on the default dashboard shows you a way to switch between any number of cameras.
Look at the dashboard project to see what it does.
You can change the selection to a different method of choosing, e.g., buttons to select specific entries in the camera list.
I’m at an event and not near a LabVIEW machine for the weekend. So I can’t give you an example right now.
#25
Thanks, I’ll check it out tomorrow.
#26
Quick question.
How can I change the combobox selection with the controller? we are using xbox 360 button 7 (Back) to change the camera.
Thanks in advance, The Patient Programmer.
#27
By the way, Unity does not use C++, it uses C#.
#28
I remembered that it was something with “c.” (like I said that was like a year ago.)
Nowadays you can find me on the Babylon.js forums and what not.
Any ideas on the switchy-camera thing?
#29
To do it in the LabVIEW dashboard, you’ll need to create a custom dashboard and wire up a NetworkTables value to change the selection, then set that value in NetworkTables on the robot side.
#30
I’ll try that thursday, thanks for the answer!
#31
I hope this isn’t a dead thread, as I haven’t said anything in a while, but how do you do that? This is my first time with labview (I’m pretty good with js so I am able to do a good bit of stuff in labview because it kinda transfers over). Things like this that are specfic to labview I have no clue on how to do.
direction would be nice.:upside_down_face:
Givo
#32
I’m not very experienced in LabView either. Hopefully someone else can chime in.
#33
Heh. That makes two of us.:upside_down_face:
On other forums I could ping people that help me a lot, but I can’t here. But maybe @Mark_McLeod or @0x54796C6572 could help, as they have tried to help me on this topic.
#34
Sorry, I’ve never used LabVIEW or the LabVIEW dashboard either. As I mentioned, we did this using a modded SmartDashboard, which changed the camera stream’s URL based on a networktables value. I’m not sure if that’s a thing built into the LabVIEW dashboard, or if you have to mod it also…
#35
You can make a labview dashboard project, but with @Peter_Johnson’s idea of
I don’t know how to do that.
Thanks anyway, and sorry for the ping.
#36
Hmm, I’ll take a look into it then. I’ll tell you any progress I make.
#37
For my SmartDashboard dual-camera project, I found the source for the SmartDashboard and modified it directly to add the functionality I wanted. However, I can’t seem to find the source code for the Default/LabVIEW dashboard. @Peter_Johnson, do you know where I can find the source code, or is it closed source and/or is integrated into the Driver Station itself?
#38
A custom LabView dashboard is created by creating a new dashboard project in LabView (same menu where you create a new robot program).
#39
Oh I see what you meant… In that case then unfortunately I won’t be able to help. I don’t have any experience with LabVIEW and I don’t currently have it installed anywhere… Sorry about that.
#40
It’s fine. I’ve found a dual camera settings config that runs the both at the same time.
320x160
10fps
80% compression
and combined the use on average 0.4 Mbps, and at most around 0.7.
Gotta keep the Mbps down this year!
