I figured a bit of stereovision would be neat this year, and plan to use two CMUCams. My question is this - how would I hook them up? One would obviously be hooked up via the TTL-RS232 converter, and the other one? Into the programming port, possibly?
I looked at Kevin Watsons serial drivers, and this might be a possibility.
yeah you can hook up the second camera to the programming port. in kevin watsons code there is an option for enabling this serial port. It is used in the same exact way as the ttl port
Again, you don’t have a clue what you’re talking about.Please stop spreading disinformation around the forums.
The camera only generates a few hundred interrupts per second, one per byte received. The serial driver is very efficient and can easilly handle this load.
Furthermore, there is no reason that you couldn’t have two instances of the camera code running, you just need to make sure each instance isn’t using the other’s global variables.
Technically, he is right. in an UART, each byte is 10 bits (1 start, 8 data, 1 stop). running at 115200 continuously gives 115200/ 10 * 2 interrupts / second for the recievers alone.
Of course, the PIC can handle that, considering that the cameras will not continuously send data, however, a few thousand interrupts per second will be generated.
I don’t choose to argue about anything. I’m right and you’re wrong. The serial data from the camera generates just over one hundred interrupts per second, not “a few thousand” and certainly not “11520”.
You’re right. I believed that the data packets were larger, but after checking the code carefully I found that I was wrong. Sorry if I seemed too jumpy.
