Hi my team uses two double solenoids for two different system , we noticed that one of the solenoids is not working while the other is not.
We changed the solenoid and the connections and we know that it’s not related to the solenoid itself but something in the code.
Is there something that you have to do when you use 2 double solenoids that you don’t do when you use one?
Please share your code. Also, please describe what you’ve tried for troubleshooting, along what more specifics around what “is not working while the other is not” (I assume that’s just a typo)
Are they identical solenoids? More specifically, is one of them a 12V and the other a 24V? Both have been available as KOP items in the past, and running a 24V solenoid on a 12 V PCM will make the LEDs change but won’t fire the solenoid.
As you note, it looks like something in the code. Echoing @Fletch1373, please provide a link to your code, preferably in github or similar.
thnaks we checked the solenoid and it seems that this was the problem thanks!
You’re welcome.
I’m not saying we’ve done that a hundred times in sixteen years, but I’m not not saying it, either.
