2 motors one jaguar
Hey CD,
Our team has two motors that will be used for the conveyor belt and we were wondering that if it is possible to have the two motors hooked up to one jaguar, because they both are on the same speed.
Thanks
Only if such is allowed for those motors. Check the Motors & Electrical sections of the rule manual.
This is allowed for certain motors, but not all.
maybe
Table 4-4: Legal Power Regulating Device Use
Electrical Load
Jaguar, Victor, or Talon motor controller
M3-RS390-12
M3-RS395-12
M5-RS545-12
M5-RS555-12
M7-RS775-12
262100-3030
262100-3040
ARA Window motors
AE235100-0610
Up to 2 per controller
*Multiple low-load, pneumatic solenoid valves or lights may be connected to a single relay module. This would allow one (1) relay module to drive multiple pneumatic actions or multiple lights. No other electrical load can be connected to a relay module used in this manner.
R53
Two of the following can be used per controller:
am PG motor
M3-RS390-12
M3-RS395-12
M5-RS545-12
M5-RS555-12
M7-RS775-12
262100-3030
262100-3040
ARA Window motors
AE235100-0610
am-2235
R52 does allow some motors to be hooked up with two motors controlled from one speed controller.
No what? That you can’t hook up two motors to a Jaguar, contrary to what R52 states? As long as the OP is using a fairly low draw motor, it would be alright. As stated before on these forums, spreading bad information is much much worse than having no answer.
you are right I noted the motors above… after an edit
I hit the key too quickly… you guys are fast
You should double check before posting anyway.
Rule R52 Table 4-4
Thanks for the advice.
I corrected it within 5 minutes of hitting the enter key by mistake…
sorry to have bothered you …
According to Table 4.4
in R 52
The am-9012 cannot be connected two to a motor controller
Please Read R52 in the manual
