2 questions
hello…i have two quick questions…are the balls on the field placed on a rack or on the floor ?
adn the wheels from skuway…can we just buy the hubs and put anything we want around them ?
well thanks
Martin
907
the balls are placed just on the floor, their is no rack and I’m not sure about your second question, my guess would be you can’t just buy hubs, but you can alter wheels to fit your needs once you get them? Can anyone better answer this question?
can we use any type of pneumatics we want ???
we have alot of good stuff but unfortunatley…we might not be able to put it to good use.
Martin
907
Martin
907
—The balls will be placed on the floor
—You can purchase wheels from Skyway and get rid of the wheel tread and just use the hub, BUT you must only use parts in the Kit or on the add. hardware list to re-cover the wheels.
—(What do you mean by pneumatics exactly…?) As far as cylinders go, you can only use the ones provided in the Kit and the four that you can order (look in the pneumatics kit of parts list for the order sheet).
and as far a solenoids go, you may only use waht is included in the kit
