It does, but why? You can already put the spare mechanisms in the bag. Why spend the extra time/effort to assemble “spare” robot, find a way to attach it to “game” robot, split apart the two pre/post inspection, then disassemble the second? I didn’t assume that’s what you were saying because honestly, it doesn’t make sense. If you have time to build the spare subsystems, just put them in the bag and save yourself a lot of time and hassle.
Very sparingly. As you may recall, that’s why I originally deferred to you prior to not getting the question answered. In Texas, there’s a stronger foundation of RIs than there are CSAs/Refs for many events. As a result, I tend to perform the latter roles.
I think we need to again look at the comment I replied to.
The comment I replied to intended to have both of the robots be a single robot for the purpose of inspection. As my reply was to point out that wouldn’t make it legal, your arguments saying I’m wrong imply you believe it is legal or you didn’t read the original comment.
Future comments you’ve made show you agree with me. You just don’t realize it.
This is honestly something that should have been posted several posts back. It’s good to be aware the rule wasn’t written any differently. It was my understanding this had changed. That said, I’ll address the next point (order changed for coherency).
The first statement isn’t logically true. Many people include arguments that aren’t relevant simply because they think it helps explain their point. Your inclusion does not inherently mean they’re relevant. Now, as to why you may think they’re relevant, that can help get through to you if we’re arguing the same point. You’ve never been arguing that point in any of this. That said, I’ll look again at your Batman and Robin and show how it remains irrelevant even without a rule change.
- Correct me if I’m wrong, both the solo Batman and the Batman/Robin configurations were inspected.
If so, this doesn’t bring anything to light when discussing robots intentionally kept together for the purpose of inspection. In this case, the team was open about their intents and designed a pair of robots meant to work together within the rules of the game. Their intent is not to split the two apart to cannibalize from the second.
- Batman and Robin were very different in design. I feel it’s safe to claim the design of Robin was more of a subsystem of Batman than an individual robot. While it aids the task of Batman, it wouldn’t be able to play the game alone. To a reasonably astute observer, one could make the argument this robot was not designed to play the game.
When the two robots are identical, none of those arguments are in place. They’re designed identically. If one is designed to play the game, the other is as well.
- It’s already been mentioned rules were a bit interesting in 2015 in part due to lack of bumpers. The same quirks we saw in that year wouldn’t apply to this year. Similarly, the beautiful 3310 robot from 2015 wouldn’t have been legal in recent years either. (Extension well beyond frame perimeter allowances).
You’re focusing on the fact there were two robots. But, it’s so far from the posed situation that it doesn’t really shed any light.
The first point has to be a misrepresentation of my points. I’ve stated I don’t believe the Robin example is relevant. Showing that Robin works does not show the idea posed in this thread works.
Let’s correct that (from my perception):
–Jeff: If the top robot/superstructure is removed, the entire inspection is invalid because of either the large weight loss or the two robots.
–Eric: If the top robot/superstructure is removed, the base still has a valid inspection, despite the loss of weight. The superstructure does not.
–What Jeff thinks Eric is saying: If the top robot/superstructure is removed, the base still has a valid inspection, despite the loss of weight. The superstructure does not.
I’m pretty sure we agreed to that when I corrected your incredibly condescending, and inaccurate, grammar lesson. Yes, we agree. If the full robot is brought to inspection and passes, there is one robot.
This has essentially been my point from the start. If somehow this bypasses the initial inspection by the RI, it’s something that would cause for pulling the inspection. If this was the intent, the team would need to show “very quickly” they only have a single robot instead of two. This is why I say you agree with me. You just haven’t read what I replied to.
[quote=EricH;1812756 C05 penalties go into effect (I04 doesn’t have any penalties listed.) Odds of getting caught? Pretty good, not perfect but pretty good. And again, the inspectors would get involved and one part would be out the door–this time, without the option to prove that it is in fact one robot.[/QUOTE]
Again, this shows you agree the inspection wouldn’t be valid once the two are split if the single robot passed inspection. Do you believe there’s a way a team can fix that? Sure. But, I never said there wasn’t. In addition to removing it from the building, I’d expect the option to disassemble would also be afforded the team along with the suggestion to handle it as disassembled parts in the future.
is a lot less significant–to a typical inspector–than half the robot weight on. It’s generally a disadvantage to the team doing it, at least initially–it’d take a real nitpicky inspector or LRI to take a disadvantage and make it worse by requiring a full reinspection any time a team removed something large and tried to play. (The other item I would comment on: The definition of “significant” is left open. I would posit that it can vary based on things other than sheer magnitude of the weight or size–another time, maybe.)
Bold for emphasis. This is why I say most of your points are irrelevant. Yes, we agree it’d be incredibly harsh for a RI to take a disadvantage and make it worse by adding more on top of it. This is even assuming a team removing a broken subsystem could pass the inspection in a couple of minutes while working on the robot. It’s still harsh.
But, the word you used here is important: generally. We’re not talking about a general case. We’re talking about a specific case. In the specific case posted in this thread and now quoted to you twice, the suggestion was to build a single robot from two identical robots with the end goal being getting two robots into the event. As that’s not a disadvantage, anything discussing how RIs/volunteers would handle a team facing an obstacle aren’t relevant. Instead, we’re discussing how they’d handle a team that intentionally is trying to walk a fine line with the rules to get around restrictions. As you’ve stated in this post, you’d agree it would be handled differently. By a seasoned RI, you’d expect this to be handled before the initial inspection is completed. By a RI that misses this, you’d expect it to be handled after the inspection. In neither scenario do you see the inspection being valid until steps are taken to remedy the violation.
At this point, here’s the summary to clear up confusion:
–Jeff: No, you couldn’t build a single robot for the purposes of bypassing the inspection. Once you split them up, it’d invalidate the inspection because your new setup would violate multiple rules. You’d need to correct those rule violates before having your inspection reinstated. As the corrections would negate the value you’re seeking to gain, there’s no point in attempting this.
–Eric: While I agree with that, I’m going to attempt to be a stickler about Jeff saying the inspection wouldn’t be valid initially because at some point, it could be.
That’s really what it comes down to. Again, you either haven’t read what I replied to, what I’ve said, or you’re just trolling. Given your responses, there isn’t any other alternative.
As my original intent was to understand how you believed the trench coat robot would pass inspection and maintain a valid inspection once the superstructure was removed with the intent of being a second robot has now been clarified (you don’t, you were just arguing), I’m going to exit this thread. There’s no point arguing just to argue.
If we consider Game Updates to be rules, which I’d argue they are, we see multiple instances each season where rules are written in response to just one team. I don’t think this is all that important. But, if happens often that one team exposes something the GDC hadn’t considered. This is true whether other teams are looking at it or not or even if the initiating team intended to perform the action.
I don’t think anyone believes there’s any ill intent here. When I point out teams, they are just teams that I know pushed the limits of specific rules. When those limits are pushed, discussion will almost certainly take place and whether the rule itself is rewritten (either in a Game Update or in future manuals) or if there is guidance on how to interpret the rule. In my experience, teams that push these conversations generally take pride in it. “Did you see the Game Update about us?”
That said, if anyone took offense (especially Marshall) for me pointing out his team does an excellent job of lawyering the rules, I apologize.
Now this makes me curious. Given the blue box for C05, how would the bag change keeping the robot in the bag or out of the bag? (For Eric’s sake, this is me deferring to Al knowing he has far more experience with this topic than I do)
“Entering” a ROBOT (or Robot) into a FIRST Robotics Competition
means bringing it to the event such that it’s an aid to your Team (e.g. for
spare parts, judging material, or for practice). Spare FABRICATED
ITEMS may be brought to the event in a bag or part of a WITHHOLDING
ALLOWANCE.
If the robot is just sitting there providing no aid to the team, why would it matter if it came in the bag versus came with the tools? I’d expect if it’s illegal out of the bag, it’d be illegal in the bag as well for all of the same reasons.[/quote]
