I just realized that I forgot to document the image orientation. If you’ve mounted the camera in the orientation I suggested, with the power switch down, the image is upside down with pixel 1,1 is located in the lower right corner. If you mounted the camera per the manual, with the power switch up, the image is right side up with pixel 1,1 in the upper left corner. If you mounted the camera any other way, you’re on your own <grin>. I’ll add this information to the camera FAQ.
