2007 Default Code?
Anyone know where it is?
lmao… i guess its in the box with all of software
The 2006 code is availible at IFI Robotics, and although the 2007 RC is likely to come with a different version, the general structure will no doubt be the same. If you’re just looking for a platform the start development, the 2006 user code is a good place to start. You should only have to copy over your user-created files and anything you add to User_Routines.c and User_Routines_fast.c.
The 2007 Code for easyC will be posted on: http://www.intelitekdownloads.com/easyCPRO/
Kevin’s code is up on his site. Scroll down a bit to find it.
Can’t seem to find default code for 2007 yet. Anyone know where I can find it or will find it eventually?
The default code is generally found at IFI Robotics. The 2006 code was last updated on 12/28/06, so it’s likely that the 2007 code is not very (if at all) different. This is where the code would be most likely to show up if the 2007 is any different. Seeing as the controller has not changed for the 2007 season, I’d guess there is no change in the default code.
where? that’s 2006 at the bottom
Thanks. I realized that after I thought about it. The controllers changed from 04 and 05 though. We figured that out the hard way last week! :smiley:
I guess I’ll be testing it out in FusionEdit.
EDIT: If it came out in December then they made two spelling mistakes on the site. The download file is 2-28 and it says right next to it 21-28.
I believe the 2006 code IS the 2007 code. Seeing as MPLAB compiler version and IDE did not change from last year, I would assume that everything works the same. Check Kevin’s site. The files were updated last year, but now say “2007 Default”.
That is convenient for us proggers as we don’t have to port our already running cam routines :slight_smile: Now…to work with 2 lights at the same time rubs chin
Yes, exactly. Last year Dave dropped the hint that the CUMcam2 would be back, and I’m hoping teams have spent some time in the off-season working with the camera.
The best thing to do at this point is to spend some time thinking about what the camera will “see” from the starting area. It’s important to know a few things:
  1. The camera has a very wide field of view of ~60 degrees.
  2. The camera will not always “see” two lights. Recent data taken on a regulation field shows that the camera will only detect a single light if it’s within about +/- 25 degrees of rotation relative to the camera.
  3. If two lights are detected by the camera, the camera will return a single rectangle around both lights.
  4. If only one light is detected by the camera, the number of pixels reported by the camera will be small (~10).
-Kevin
I thought the rule was we are not allowed to reuse code. Ill have to check this years manual though.
This rule has always been vague and debated. Use good judgment (and GP).
My personal policy is that: (1) You should be allowed to use any libraries you (or anyone else) have developed; (2) You can copy/paste trivial snippets that, if developed from scratch, would look nearly identical anyway.
Of course, using previous code as a guide to writing this year’s code is perfectly fine, IMHO. (I haven’t gotten to that section of the manual yet.)
Also, retyping should be considered the same as copy/pasting. This goes for competitions as well. If you bring print outs of code that you just type into the laptop, why not just bring a flash drive with the files? The manual is pretty clear, though, that writing code during the fix-it windows for your specific robot is off-limits. You may design, structure, outline, etc. code. See the section on the robot for details.
Whats the difference between the new Rev A CMUCam and the one from last year? Anything we should be aware of? Where are the updated docs?
the the kick off video the showed a screen displaying number of targets and some other info. Is that available anywhere? Or is the multiple target comment a red herring?
BrianC
That code is available here.
At least one difference between the camera’s is that this year’s camera does not have the capability to drive servos.
You’re kidding me! You mean at a hardware level it can’t drive servos?
I loved that bit. When we have an already overloaded processor (and likely to be more so this year), with poor timing for a “real-time” application, I love being able to offload features for basically free. Less wires to run, less outputs to use, less code to write and tweak, etc.
Sorry, but yes you are correct this years CMU cam has the headers for the servos removed.
But, as far as my understanding of the rules goes, you can still use last year’s CMU cam instead if you want this functionality. Otherwise you could probably offload some of the camera stuff to a second processor if you felt the need to, but I don’t think i’s necessary unless you’re doing a lot of other complicated things.
If they were removed, was anything added? Or just blank board space?
look for yourself it just looks… different
