2008 Easy C Pro
Downloaded to our new labtop (sadly running on vista) Havent had any problems yet but I’ve noticed that icons and robot computer board are for Vex. Is it still compatible with FRC or is there something I have to change/get/download? Any help will be great. Thanks
Hi Liam,
You just need to switch it over to the FRC Controller of your choice. Go to “Options”, then “Robot Controller Setup”. You’ll see a window open with two dropdowns. From there, change the Robot Controller to “FRC”, and then make sure the 2nd dropdown has “FRC 2006 - 2008” selected.
Good luck!
JAB
slaps forehead Thanks, just noticed that not to long after the post. Thanks for the reply.
