Hello we are currently trying to image our cRIO with the current 2011 image. While applying this update we have run into the following error
Unable to complete operation because of unexpected error 60:
UDP Open in repFPC open connection.vi->SendRebootCmd.vi->RebootSystem.vi->Format Target.vi->ConfigUtility.lvlib:ReImageTarget.vi->ConfigUtility.lvlib:Dialog.vi
We have tried formatting the cRIO but the error persists. Any help is apprieciated
That usually means there is some network trouble between your laptop and the cRIO. Often it’s not a connectivity problem, but just bad timing.
Simply trying it from a different computer sometimes works.
You can try hooking the two (cRIO and laptop) together different ways
Turning off laptop network cards that aren’t being used (The Imaging Tool could be getting confused over when network to try).
Directly connect laptop to cRIO
*]Alternatively, try connecting through a router, e.g., the D-Link that came in the kit. A router can somewhat smooth the network changes that the Imaging Tool makes to the cRIO.
