Not necessarily, depends on when it’s used and what other actions are performed.
I can’t tell if this is a pointless rant or if you’re being serious.
What wireless protocol and frequency would you use? 2.4Ghz? 5Ghz? Something other than wi-fi? There isn’t much to switch to that isn’t regulated.
The frequency is only part of the problem. Sure there is a lot of noise at 2.4 GHz because of the prevalence of Wifi, but I feel like most of the problem is the protocol. There are numerous hobby/RC bands just outside of 2.4 GHz that have no trouble maintaining a connection, even with several hundred controller/vehicle pairs in a smallish area, and I feel it’s mostly because the nodes know exactly who are they are trying to talk to and don’t have to deal with traffic from a gazillion other nodes (or if they do, because it’s not fully scalable like IP, it doesn’t have to look through and potentially forward every packet coming in, it can just ignore most of them). FIRST itself had a band for its own competition in 2008 and prior. In terms of regulations, for short range broadcasting I’m fairly certain there are a lot of bands where you don’t need to tell anyone about what you’re doing (I’m talking something like less than a few hundred meters). I’m sure there are some Ham radio buffs around here somewhere who know all about this.
I have a post from last year explaining the problem. The issue manifested at FLR and Florida, and matches couldn’t be run until they were able to get the venues to shut down some of the APs.
Ah the memories (Actually more like AHHHHHHHH! THE MEMORIES! as they drag you off to the padded room in a straightjacket).
As stated above, this issue did occur in Florida last year. Considering that the regional is on UCF’s campus, a campus with over 50,000 students, it’s not a surprise that there was a lot of wifi in the area. Teams would spend over 5 minutes trying to connect to the field only to be told to try again next time because it was taking too long. Once a team did connect, however, their chances of being found the next time increased exponentially, at least that is what was explained to me. I believe that is why the problem only really occurred on Thursday, because by Friday everyone had been able to connect at least once. At our next regional the FTA wanted everyone to connect to the field at least once on Thursday whether or not they were inspected, probably for this reason.
I think you’re misreading that. I think your configuration would be illegal because if the bot were placed flat on the bridge or carpet your bumpers would not be entirely in the zone.
But I think his point is that the robot is already flat on the bridge, the or only requiring one of them to make it legal. And of course what is “flat?”
Not that I know all of the details on the radio issue, but it sounds to me like they have identified a firmware issue with the model that they were using. It sounds like working with the radio providers, they have identified a model without the issue. Rather than replace all the radios for a rare complication, they have a plan to deal with a known issue if and when it occurs.
Again, I’m not an expert, but I assume that proprietary radio bands, especially ones with lots of bandwidth are susceptible to implementations issues in firmware and logistical surprises too.
There is nothing about the new system that precludes a special band or radio, but using off-the-shelf products, teams can pretty easily have their own N speed setups in their school or shop.
I’m also curious what you mean by FPGA overhead?
Greg McKaskle
I think you may be missing some of the physics. Your robot is not adhered to the bridge. Therefore you are lifting the weight off of one set of wheels and putting it all on the others. Yes, it changes the balance, but not necessarily enough to account for the distance raised. Think carefully…
If I have a 6 wheel drive robot and my CG is on one side or the other of the middle wheels, then I do not need the other set of wheels to remain flat on the bridge. If I stick something out between the wheels that are not needed (and hanging over the edge of the bridge) I will remain flat with respect to the bridge the entire time. Once balance, we retract. This update gives me the ammunition I need to fight for this mechanism.
What we really need is a clear and concise ruling on this bridge balancing device.
There is a reason many of us are asking the questions so specifically. The extra clarification in the latest update makes it clear to me that if my robot looks like it is not raising its bumper relative to the surface that it is on, then we are good.
The fact that so many of us are not in agreement means we may need further clarification.
me too, inquiring minds want to know !
They should just put big sheets of lead all around the field to stop all the arena wireless signals.
Don’t need lead. A Faraday cage ought to work just as well, and those aren’t lead.
Right-o. That’s all I was saying; that this ruling isn’t so much a ruling as an additional vaguery. I wouldn’t count on the legality until something much more explicitly phrased comes along!
The point was that the lead would prevent everyone from seeing the field. Hence the
Hmm, I don’t like the wireless bridge thing. To be blunt, I don’t have a lot of faith in last minute swapping of parts by either officials or ourselves. Our team has had trouble with that in the past and it’s been a real problem.
I think part of what it takes to do well in competitions like this is a matter of reducing risk and mitigating potential problems before they arise. For instance, last year the team counted on a potentiometer to determine position. They ended up destroying the pot (never heard how) and had to replace it. The new one wasn’t of the same value and so they immediately burned up a motor by driving past the stop on the arm. The solution would have been some calibration system combined with limit switches. That would make it possible to swap parts and even if something went wrong and been working properly in minutes. We’ve learned this lesson so this year all parts with max/min extents have limit switches along with encoders and what not.
The problem is that something with configuration like the bridge isn’t quite as amiable to swamping. A tiny setting off and nothing works and we are scrambling to track it down. We have the Axis camera, onboard computer, and cRIO all plugged into the bridge. There is a lot happening and it will have been extensively tested before the competition begins. Is there any way we could simply buy the newer bridge and use it in the competition so no swapping needed? The $100 cost isn’t much compared to the piece of mind that having it already tested and working on the bot will bring.
-Mike
The update explicitly says this won’t be allowed.
I too am a skeptic on how the whole bridge swap will work.
-How will teams mount it in a few minutes? We usually velcro our radio to our robot, then zip tie around it so it has no way of falling off. We also zip tie all of the wires to the radio in such a way that they can’t come out, and add duct tape to the wire connections since some of them are friction fit (which is really really bad, in our experience).
-The backup radio is significantly larger (~3" in one dimension) than the old one. I expect that it simply won’t fit on some robots designed for the existing radio.
-Since the backup radio runs on 12v instead of 5v, they are giving us a 4.5’ power cable to plug into our PD board? The update seems to indicate that the power cable goes with a bridge (and that each team will get a power cable in the queue line). I don’t see how they expect teams to integrate it into their wire harness (zip tie it in) if the radio is decently far away from the PD board, in a few minutes. I don’t see how they expect teams to assume reliable radio power (which is very critical) if they can’t secure the wire from damage.
-All of this is done before every match (as many as 12 quals + up to 9 elim matches)?
I echo all of these concerns. Hopefully we’ll never find out how it would work.
