So I think I have convienced my team that we need to go with the Kitbot on steriods. From what I have seen/heard this years kit bot will have belts instead of chain drive. I have no experience with belt drive and was wondering how this will change the setup of the KB on steriods. Does anyone have any suggestions to help us with this. Any help will be appreciated.
“If your team decides to receive the 2013 KOP Drive System, you will receive an AndyMark C-Base chassis system similar to the last few years. It will again be a six wheel drive robot, with similar wheels to 2012, and with enough material to drive all six wheels. The 2013 gearbox is a ToughBox Mini with 10.71:1 reduction. The estimated final drive speed is about 10 feet per second.”
The Toughbox Mini also accepts 2 CIMs so if you elect to drive each side 2 CIMS it will be very similar to the kitbot on steroids from previous years, just theoretically more efficient and lighter.
You can continue to use chain if you are more comfortable with it, sprockets are still on sale on Andymark and IFI (Vex Pro) so you can order your desired wheel and output sprockets once you’ve chosen your final gear ratio. The kit sprockets were geared too fast last year (i believe it was 26 tooth), we ended up purchasing 30 tooth ones for our 2012 competition robot.
This year’s KitBot doesn’t need much to become a kitbot on steroids, right? I think all it needs is an upgrade to 4 CIM motors and a sheet of plywood to stiffen it up. I guess some people will want plaction wheels over FIRST wheels, but I like the HiGrip FIRST wheels.
EDIT: FOund the link to the information you are referencing above.
How do you know for sure that the KOP will be the same as last year in regards to the 2013 KOP Drive System?
Was this published already?
Thanks,
Norman
The main advantage of the KBoS in my mind are the AM shifters and the extra strength from the plywood. The main unknown at this point, which could determine the possibility of running a KBoS system, is the bore of the new pulleys. The output shaft on the AM shifter is 1/2" keyed, and as much as I hope that the new pulleys will be hex, this would prevent them from going in a AM shifter. I guess we’ll all find out when the Kit Bot is released tomorrow.
I think the regular kitbot isn’t 6wd, but that could change this year
Our “plan” for this season is going to be a play on the “KOP on Steroids”.
Again, this will all depend on the game and our strategy, but for now, this is our plan.
Depending apon what the KOP actually contains…
We plan on using the majority of the drive componants from the KOP, but substituting a VexPro Ball shifter with 2 CIMs per side in place of the ToughBox Mini. We will also, if possible, replicate the dimentions of the KOP drive, but build them into our own custome frame. We may even do a riff on WCD style if possible. At this point though, it will all depend on the game and what the KOP actually contains. One thing is certain though, we will be using belt drive.
I’m pretty sure the KBoS uses the kit CIMple Boxes, and where did you hear about the Kitbot being released tomorrow?
I think they switched to Nano Toughboxes this year.
Where you’d expect, actually. “AndyMark Drive Base Kit…Checklist (coming 1/2/13)” [so actually today, now]. Rather odd, but there. Let’s see if it happens.
Ok, I will volunteer the collective advice on behalf of the all the FRC participants and mentors who are face-palming while reading this post. If you have genuinely “decided” or “convinced your team” what drive chassis you will use this year before even seeing the game, your team may want to fundementally rethink your approach to this activity.
I agree today “should” be the date the Checklist is available, BUT, has anyone actually seen it yet?
I checked the FIRST 2013 KOP site, but nothing is there yet. And nothing on AndyMark yet either.
Why is this so? We have had sub par results in our 10 years of doing it the way that we have. We dont have enough resources to devote time to custom things and would be better served using the provided frame. The rest of the team felt that this would be a good approach. I am reaching out to the chiefdelphi community asking for advice. Before I face palm in frustration could you please explain to me how my fundementals need to be rethought?
I believe he’s referring to the fact you make design decisions before kickoff, not criticising the decision itself.
What Jeff is trying to say is you can’t say you are doing a specific design for sure without even knowing what the game is. My favorite example of this is 2009, the game with regulation wheels and a low-friction playing field. If your team decided that you’d use 4" wheels and the kitbot for the 2009 season without knowing what the game was, come kickoff day you’d be disappointed to find that due to rules, restrictions, and the way the game was played, that the chassis you decided on using either isn’t allowed, or isn’t the best solution to the game.
He isn’t saying that you shouldn’t decide to use the kitbot and go custom. He’s saying that you shouldn’t make any decisions before you’ve seen the game and decided your strategy. This year we wanted a long robot (kitbot on steroids, to be exact) before seeing Rebound Rumble. After seeing it, we decided a wide robot would be advantageous for us due to more room on the bridge and a wider pickup area.
I believe his intent was to suggest not placing all your eggs in one basket quite yet.
Until we really know what the game is, it would be very prudent to NOT commit to any design specifics just yet.
As an example:
If you had decided and committed to make a high torque, multi-speed drive train before kickoff in 2009, when Lunacy was introduced, you would find you had shot yourselves in the proverbial feet.
The game can dictate different aspects of a drive-train.
Now, based on what we KNOW is included in the KOP this year, the assumptions on the needs of the drive-train for 2013 can be narrowed down quite a bit.
4" high grip wheels, ToughBox Mini transmissions with 10.7:1 reduction, belt drive up to 6 wheels, from the KOP. Based on those facts, you should be able to get fairly close to a final decision without even seeing what the game is.
But, nothing should be set in stone just yet.
I feel your line of reasoning is sound and that taking a good objective look at your performances and resources is always a good thing. It is however good practice to withhold all design decisions until the game is announced. While the kitbot is almost always a viable drivetrain, and you have probably committed to it from a resource standpoint by choosing it above the voucher, it is still good practice to take another look at it at the start of the season. Odds are probably around 99% that you will go with your kitbot and never look back, but there is always the possibility that the design is not optimal for the game in question.
I am refering to the idea of “deciding” or “convincing” your team what drivetrain you will use, or any other detail about your robot, before anything about the game is known. Making design decisions before any of the criteria are known. That is the approach I am advising rethinking. What if the KBoS is entirely inappropriate for the game? Bumps, ramps, obstacles, stairs, platforms, climbing, etc., etc. Design is the process of meeting and reacting to a challenge. Design decisions before the challenge is even known are just a shot in the dark. What is more likely to succeed, a decision based on the challenge, or one made before the challenge is even known?
