Alright ladies and gents, now the fun part. What is the max score that each side of the fields can come up with? Highest auton score? What will be the highest stack of the year? What scores do you expect from weeks 1 and 2 all the way to champs?
(Im looking at rules and crunching numbers as I post)
Im trying to figure out the wording on the auton. Can you move the grey bins in auton? I havnt found a rule about it, I dont think it was mentioned. Does the 20 stacked bin mean if you had 3 on the scoring spot, 2 stacked one not you would have 2x20 plus 1x6?
EDIT: Im looking but havnt found anything about it yet
there are several ways to handle auton scoring as I read the rules now.
32 point method (A):
-4 points awarded for all active robots in auto zone (Robot Set) (4pts.)
-6 points awarded for 3 totes in auto zone (Tote set) (6pts.)
-14 additional points awarded for stack (Stacked Tote Set) (14pts.)
-8 points awarded for any three recycling containers in auto zone (Container set) (8pts.)
Total: 32pts. Max
32 point method (B):
-6 points awarded for 3 totes in auto zone (Tote set) (0pts.) (included in Stacked Tote Set)
-14 additional points awarded for stack (Stacked Tote Set) (20pts.)
Total: 32pts. Max
38 point method:
Total: 38pts. Max
it is still up to debate if you can get a Stacked tote set and a regular tote set scored at the same time.
I agree with your max, but you only get points for sets, so you need all yellow totes in the auto zone to get 6 points, you cannot get 4 points for only having two of them. The recycling containers only needs one to have a set.
Grey totes aside, lets look at the gold ones. lets have 0 be a golden tote and ___ be the ground. Ill give you the situations I see happening.
0___0___0_ =?
.....0
0________0=?
...0
...0
0______=?
How many points would each situation be worth in auton? Would it be 6 (2 points each) on the first, or 18 points, 6 per.
Would the second be worth 20+6 (one stack one alone)? 20+2(this would be if scoring totes alone in auton are only worth 2)?
Would the last only be worth 20? It seems like quite a feat to get 3 stacked in auton. Im sure we will see it, but it seems insignificant if you look at what you can score after Teleop starts.
I originally thought the coopertition points were a red herring since they won’t really affect ranking since averages are calculated to 2 decimal places but the high value of the stacked totes probably means each alliance should try to put two yellow totes on the step once it is clear of grey ones. Assumes another robot will complete the stack of 4.
