So where do I find the Multiple Activation Key?
Method 1: Use a Multiple Activation Key instead of KMS activation
Click here to collapse or expend the section
If KMS activation will not be used, and if there is no KMS server, the product key should be changed to an MAK. For Microsoft Developer Network (MSDN), or for TechNet, the stock-keeping units (SKUs) that are listed below the media are usually volume licensed-media, and the product key that is supplied is an MAK key.
Change the product key to an MAK. To do this, follow these steps:
Click Startthe Start button, click All Programs, click Accessories, and then right-click Command Prompt.
Click Run as administrator.
User Access Control permissionIf you are prompted for an administrator password or for confirmation, type the password or provide confirmation.
At the command prompt, type the following command, and then press Enter:
slmgr -ipk xxxxx-xxxxx-xxxxx-xxxxx-xxxxx
Note In this command, the placeholder xxxxx-xxxxx-xxxxx-xxxxx-xxxxx represents your MAK product key.
