My FRC team is attempting to decide what to put down for our FIRST Choice requests. We were unsure as to what things we would be receiving in this years kit. New set of electronics? New talons? If anyone has any insight on this We would appreciate a response. Thank you.
If you go into an individual part in FIRST choice, there is a table including one row labeled “In Kickoff Kit” that specifies whether it’s in the KOP, and if so, whether the rookie kit, veteran kit, or both.
Mark McLeod’s spreadsheet, posted here, includes a column about whether it’s in the KOP and is probably the easiest way to find this information. I also copied the parts he listed as being in either kit below (details about which kit it’s in are in the column to the right).
In addition to that, every team will get a voucher for 3 Victor SPs or 2 Talon SRXs (information form this blog post).
USB A Male to B Male, 2m, Black (fc16-067) Rookie
Throttle Motor (fc16-019) All
Teflon tape PTFE-1/4 (fc16-054) Rookie
PSoC 5LP Prototyping Kit (fc16-030) Rookie
Power Distribution Panel (fc16-023) Rookie
Pneumatic Pressure Switch (fc16-069) Rookie
Pneumatic Cylinder (fc16-097) Rookie
Pneumatic Control Module (fc16-022) Rookie
Parker Fitting Kit (fc16-104) Rookie
Micro switch, set of 10 (fc16-037) All
Industrial RJ45 Modular Plug (fc16-001) All
igubal spherical rod end bearing EBRI-10R (fc16-057) All
igubal spherical flange bearing EFOI-10R (fc16-058) All
iglide plastic thrust washer (fc16-108) All
iglide plastic sleeve bearing (fc16-107) All
iglide plastic flange bearing (fc16-106) All
iglide plastic clip bearing (fc16-109) All
Freelin-Wade WhiteTubing (fc16-043) Rookie
Freelin-Wade Transparent Blue Tubing (fc16-042) Rookie
Freelin-Wade Red Tubing (fc16-041) Rookie
Freelin-Wade Blue Tubing (fc16-040) Rookie
Freelin-Wade Black Tubing (fc16-039) Rookie
Compressor, Model 90C (fc16-102) Rookie
Battery Connector from Anderson Power Products (fc16-008) All
Air Volume Tank, 32 cu. in., Black Plastic AVT-PP-35 (fc16-021) Rookie
2-Position & 4-Position Link Connectors, Qty 10 each with 6ft Cable (fc16-002) All
12V Battery NP18-12 (fc16-036) 1/Veteran, 2/Rookie
This data is posted on the FIRST Choice site powered by AndyMark, so I would consider it trustworthy, bordering on authoritative. Here’s an example: the battery page. The first row of the Product Specifications table tells you that there is 1 for veterans and 2 for rookies.
