District Ranking Points for 1st event only.
Rookie and Sophomore Team bonus cut in 1/2 to reflect only 1 event. (This is reflected on Mountain Man’s spread sheet, but not at the time Rangel copied it.
The only errors I see at this time are the Award points for 6530 and 60. They are 5 points too high. My guess is they got credit for their Finalist Award, but shouldn’t since it is not a judged award. (If that is the source of error, strange that did not happen with 4146.) That would explain why 60 is 3rd instead of 2nd.
6518 played in the semifinals at Arizona North for 1 match as a back-up replacement. The original list has them ranked higher because they were given credit for advancing to the semifinals. This is an error according to the manual. Mountain Man’s Spreadsheet is more correct in this instance. They are still in the top 30 however. (25th)
10.12.3.2 Playoff Round Performance
This attribute measures Team performance as part of an ALLIANCE.
All Teams on the ALLIANCE winning a particular playoff series, who participate in MATCHES with their
ROBOTS, receive five (5) points per MATCH won. In most cases, Teams receive ten (10) points at each
of the Quarterfinal, Semifinal, and Final levels, unless a BACKUP ROBOT is called in to play.
I don’t see tie-breakers tabulated in Mountain Man’s Spreadsheet. Could explain why 498 and 6674 are flipped?
3577 had a Quals rating of 13 for me instead of 12 for Mountain Man. May be a difference in how the formula is approximated in the spreadsheet? 4841 had 8 instead of 7 for me as well.
=IF(O3=0,0,(ROUNDUP(IF(P3<=O3,IFERROR(SQRT(GAMMA.INV(((O3-(2P3)+2)/(1.07O3)),0.5,1))(10/(SQRT(GAMMA.INV((1/1.07),0.5,1))))+12,24-(SQRT(GAMMA.INV((-(O3-(2P3)+2)/(1.07O3)),0.5,1))(10/(SQRT(GAMMA.INV((1/1.07),0.5,1))))+12)),“”),0)))
4841 was accidentally credited with an extra 5 award points. A carry-over from a hand correction when the spread sheet was used for Missouri. 3944 (on tie breakers) would be the 30th ranked team.
PS. I don’t run the Arizona Event, but I did give a consult to those who do based on my work with the Missouri State Championship.
