[2018] CMP Prop Bets
It’s that time again!
New for this year (and similar to last year!), we’re going to pit Houston versus Detroit.
Following the same format from 2013-2017 post whether you think the statement will be true or false. Betting stops when Detroit matches start. Good luck!
http://www.chiefdelphi.com/forums/showthread.php?t=136661
http://www.chiefdelphi.com/forums/showthread.php?t=115914
http://www.chiefdelphi.com/forums/showthread.php?t=128855
https://www.chiefdelphi.com/forums/showthread.php?t=147359
https://www.chiefdelphi.com/forums/showthread.php?t=157996
AGAIN for 2018 - I’ll be offering a $50 Amazon gift card to the winner.
Once Detroit finishes, statements will be evaluated and answers posted, and the winner will be notified via PM. I will require a valid email address to send the gift card. Any answer disputes must notify me within 24 hours of answers posted (I’m human, after all). Once 24 hours clears, I will send the gift card to the Winner. Once the winnings are payed the contest is concluded, no more disputes. My contest, my rules. Don’t like it? Run your own contest!
(Thanks Dr. Joe!)
**To help speed scoring, please use code tags around the following. **(Just copy and paste ALL of the text in the block in a new post, and begin and end with code ] / code ], omitting the spaces. Quote this post to see examples of code tags in action!
PLEASE put TRUE or FALSE before each numeral, e.g.
FALSE 1. The Houston Championship will score… **
Omitted answers will be assumed TRUE, tiebreakers will be assumed +infinity.
Lets go!
1. The Houston Championship will face the boss (qualification only) more than the Detroit Championship
2. The Houston Championship will auto quest more (qualification + elimination)  than the Detroit Championship
3. The Houston Championship will score more total points (qualification + elimination) than the Detroit Championship
4. The Houston Championship will score more total ranking points than the Detroit Championship
5. The Houston Championship will play more elimination matches (both division + Einstein) than the Detroit Championship
6. The Houston Championship Einstein field will score more points than the Detroit Championship Einstein field
7. The sum of the team numbers of both Einstein fields will be even.
8. The sum of the team numbers of both Einstein winning alliances will be even.
9. The average team number of all Einstein robots will be greater than 2700.
10. Carver will score more qualification points than Archimedes
11. Galileo will score more qualification points than Carson
12. Hopper will score more qualification points than Curie
13. Newton will score more qualification points than Daly
14. Roebling will score more qualification points than Darwin
15. Turing will score more qualification points than Tesla
16. Carver #1 seed will have a higher ranking score than Archimedes #1 seed
17. Galileo #1 seed will have a higher ranking score than Carson #1 seed
18. Hopper #1 seed will have a higher ranking score than Curie #1 seed
19. Newton #1 seed will have a higher ranking score than Daly #1 seed
20. Roebling #1 seed will have a higher ranking score than Darwin #1 seed
21. Turing #1 seed will have a higher ranking score than Tesla #1 seed
22. The #1 captains of Houston will have a lower average team number than Detroit
23. The #8 captains of Houston will have a lower average team number than Detroit
24. The same color alliance will win the Houston Championship as Detroit
25. The winner of the Houston Championship will have a higher average score than Detroit
26. There will be an even number of finalists matches played on Einstein
27. The sum of the Chairman's Award winners will be even.
28. The sum of the Chairman's Award Finalists will be even.
Tiebreaker #1 - Predict the sum of the team numbers of all Einstein champions (closest without going over wins)
Tiebreaker #2 - Predict the total points on Einstein (closest wins).
There will not be a split prize. If Tiebreakers #1 and #2 fail, the prize will go to the earliest entry (timestamp of post or most recent edit at the time I grab the entries).
In the spirit of FIRST Power Up, I’ve determined my answers using the random.org coin flip function 28 times (a 25 cent Connecticut quarter, because NE things). Heads become true, tails become false.
Tiebreaker 1 was a result of putting two high ranked NE teams (125 + 78) together that were close to what I wanted.
Tiebreaker 2 was conducted similarly (95 + 88).
TRUE 1. The Houston Championship will face the boss (qualification only) more than the Detroit Championship
FALSE 2. The Houston Championship will auto quest more (qualification + elimination)  than the Detroit Championship
FALSE 3. The Houston Championship will score more total points (qualification + elimination) than the Detroit Championship
TRUE 4. The Houston Championship will score more total ranking points than the Detroit Championship
TRUE 5. The Houston Championship will play more elimination matches (both division + Einstein) than the Detroit Championship
FALSE 6. The Houston Championship Einstein field will score more points than the Detroit Championship Einstein field
FALSE 7. The sum of the team numbers of both Einstein fields will be even.
FALSE 8. The sum of the team numbers of both Einstein winning alliances will be even.
TRUE 9. The average team number of all Einstein robots will be greater than 2700.
FALSE 10. Carver will score more qualification points than Archimedes
FALSE 11. Galileo will score more qualification points than Carson
TRUE 12. Hopper will score more qualification points than Curie
TRUE 13. Newton will score more qualification points than Daly
TRUE 14. Roebling will score more qualification points than Darwin
TRUE 15. Turing will score more qualification points than Tesla
FALSE 16. Carver #1 seed will have a higher ranking score than Archimedes #1 seed
FALSE 17. Galileo #1 seed will have a higher ranking score than Carson #1 seed
TRUE 18. Hopper #1 seed will have a higher ranking score than Curie #1 seed
TRUE 19. Newton #1 seed will have a higher ranking score than Daly #1 seed
TRUE 20. Roebling #1 seed will have a higher ranking score than Darwin #1 seed
TRUE 21. Turing #1 seed will have a higher ranking score than Tesla #1 seed
TRUE 22. The #1 captains of Houston will have a lower average team number than Detroit
TRUE 23. The #8 captains of Houston will have a lower average team number than Detroit
TRUE 24. The same color alliance will win the Houston Championship as Detroit
FALSE 25. The winner of the Houston Championship will have a higher average score than Detroit
FALSE 26. There will be an even number of finalists matches played on Einstein
FALSE 27. The sum of the Chairman's Award winners will be even.
TRUE 28. The sum of the Chairman's Award Finalists will be even.
12578 Tiebreaker #1 - Predict the sum of the team numbers of all Einstein champions (closest without going over wins)
9588 Tiebreaker #2 - Predict the total points on Einstein (closest wins).
FALSE 1. The Houston Championship will face the boss (qualification only) more than the Detroit Championship
TRUE 3. The Houston Championship will score more total points (qualification + elimination) than the Detroit Championship
FALSE 4. The Houston Championship will score more total ranking points than the Detroit Championship
FALSE 5. The Houston Championship will play more elimination matches (both division + Einstein) than the Detroit Championship
TRUE 6. The Houston Championship Einstein field will score more points than the Detroit Championship Einstein field
TRUE 7. The sum of the team numbers of both Einstein fields will be even.
TRUE 8. The sum of the team numbers of both Einstein winning alliances will be even.
FALSE 9. The average team number of all Einstein robots will be greater than 2700.
TRUE 11. Galileo will score more qualification points than Carson
FALSE 12. Hopper will score more qualification points than Curie
FALSE 14. Roebling will score more qualification points than Darwin
FALSE 20. Roebling #1 seed will have a higher ranking score than Darwin #1 seed
FALSE 21. Turing #1 seed will have a higher ranking score than Tesla #1 seed
FALSE 23. The #8 captains of Houston will have a lower average team number than Detroit
TRUE 25. The winner of the Houston Championship will have a higher average score than Detroit
TRUE 26. There will be an even number of finalists matches played on Einstein
9001 Tiebreaker #1 - Predict the sum of the team numbers of all Einstein champions (closest without going over wins)
23456 Tiebreaker #2 - Predict the total points on Einstein (closest wins).
First time doing this, lets see how it goes.
FALSE 18. Hopper #1 seed will have a higher ranking score than Curie #1 seed
FALSE 28. The sum of the Chairman's Award Finalists will be even.
5254 Tiebreaker #1 - Predict the sum of the team numbers of all Einstein champions (closest without going over wins)
12791 Tiebreaker #2 - Predict the total points on Einstein (closest wins).
TRUE 2. The Houston Championship will auto quest more (qualification + elimination)  than the Detroit Championship
TRUE 10. Carver will score more qualification points than Archimedes
FALSE 15. Turing will score more qualification points than Tesla
TRUE 16. Carver #1 seed will have a higher ranking score than Archimedes #1 seed
TRUE 17. Galileo #1 seed will have a higher ranking score than Carson #1 seed
FALSE 22. The #1 captains of Houston will have a lower average team number than Detroit
TRUE 27. The sum of the Chairman's Award winners will be even.
8381 Tiebreaker #1 - Predict the sum of the team numbers of all Einstein champions (closest without going over wins)
5026 Tiebreaker #2 - Predict the total points on Einstein (closest wins).
Thanks for setting this up!
12540 Tiebreaker #1 - Predict the sum of the team numbers of all Einstein champions (closest without going over wins)
11140 Tiebreaker #2 - Predict the total points on Einstein (closest wins).
True 1. The Houston Championship will face the boss (qualification only) more than the Detroit Championship
False 2. The Houston Championship will auto quest more (qualification + elimination)  than the Detroit Championship
True 3. The Houston Championship will score more total points (qualification + elimination) than the Detroit Championship
False 4. The Houston Championship will score more total ranking points than the Detroit Championship
False 5. The Houston Championship will play more elimination matches (both division + Einstein) than the Detroit Championship
True 6. The Houston Championship Einstein field will score more points than the Detroit Championship Einstein field
True 7. The sum of the team numbers of both Einstein fields will be even.
False 8. The sum of the team numbers of both Einstein winning alliances will be even.
False 9. The average team number of all Einstein robots will be greater than 2700.
True 10. Carver will score more qualification points than Archimedes
False 11. Galileo will score more qualification points than Carson
True 12. Hopper will score more qualification points than Curie
True 13. Newton will score more qualification points than Daly
False 14. Roebling will score more qualification points than Darwin
False 15. Turing will score more qualification points than Tesla
False 16. Carver #1 seed will have a higher ranking score than Archimedes #1 seed
False 17. Galileo #1 seed will have a higher ranking score than Carson #1 seed
True 18. Hopper #1 seed will have a higher ranking score than Curie #1 seed
True 19. Newton #1 seed will have a higher ranking score than Daly #1 seed
False 20. Roebling #1 seed will have a higher ranking score than Darwin #1 seed
True 21. Turing #1 seed will have a higher ranking score than Tesla #1 seed
False 22. The #1 captains of Houston will have a lower average team number than Detroit
False 23. The #8 captains of Houston will have a lower average team number than Detroit
True 24. The same color alliance will win the Houston Championship as Detroit
True 25. The winner of the Houston Championship will have a higher average score than Detroit
False 26. There will be an even number of finalists matches played on Einstein
True 27. The sum of the Chairman's Award winners will be even.
True 28. The sum of the Chairman's Award Finalists will be even.
12579 Tiebreaker #1 - Predict the sum of the team numbers of all Einstein champions (closest without going over wins)
9587 Tiebreaker #2 - Predict the total points on Einstein (closest wins).
Always look forward to the prop bets. Thanks for having it!
FALSE 24. The same color alliance will win the Houston Championship as Detroit
5188 Tiebreaker #1 - Predict the sum of the team numbers of all Einstein champions (closest without going over wins)
22501 Tiebreaker #2 - Predict the total points on Einstein (closest wins).
**TRUE**
**FALSE**
**FALSE**
**TRUE**
**FALSE**
**FALSE**
**FALSE**
**FALSE**
**FALSE**
**FALSE**
**FALSE**
**FALSE**
**FALSE**
**FALSE**
**FALSE**
**FALSE**
**FALSE**
**TRUE**
**TRUE**
**TRUE**
**FALSE**
**TRUE**
**TRUE**
**TRUE**
**TRUE**
**FALSE**
**FALSE**
**TRUE**
16,000
**11,550**
**False**
**False**
**True**
**False**
**Flase**
**True**
**False**
**False**
**True**
**False**
**False**
**Flase**
**True**
**False**
**False**
**True**
**False**
**True**
**True**
**True**
**False**
**True**
**True**
**False**
**True**
**False**
**False**
**False**
Tiebreaker #1 - Predict the sum of the team numbers of all Einstein champions 1000 (closest without going over wins)
Tiebreaker #2 - Predict the total points on Einstein (closest wins). 10000
 **True**1. The Houston Championship will face the boss (qualification only) more than the Detroit Championship
**False**2. The Houston Championship will auto quest more (qualification + elimination)  than the Detroit Championship
**False**3. The Houston Championship will score more total points (qualification + elimination) than the Detroit Championship
**False**4. The Houston Championship will score more total ranking points than the Detroit Championship
**False**5. The Houston Championship will play more elimination matches (both division + Einstein) than the Detroit Championship
**False**6. The Houston Championship Einstein field will score more points than the Detroit Championship Einstein field
**True**7. The sum of the team numbers of both Einstein fields will be even.
**True**8. The sum of the team numbers of both Einstein winning alliances will be even.
**False**9. The average team number of all Einstein robots will be greater than 2700.
**False**10. Carver will score more qualification points than Archimedes
**True**11. Galileo will score more qualification points than Carson
**True**12. Hopper will score more qualification points than Curie
**False**13. Newton will score more qualification points than Daly
**True**14. Roebling will score more qualification points than Darwin
**False**15. Turing will score more qualification points than Tesla
**False**16. Carver #1 seed will have a higher ranking score than Archimedes #1 seed
**True**17. Galileo #1 seed will have a higher ranking score than Carson #1 seed
**True**18. Hopper #1 seed will have a higher ranking score than Curie #1 seed
**False**19. Newton #1 seed will have a higher ranking score than Daly #1 seed
**True**20. Roebling #1 seed will have a higher ranking score than Darwin #1 seed
**False**21. Turing #1 seed will have a higher ranking score than Tesla #1 seed
**False**22. The #1 captains of Houston will have a lower average team number than Detroit
**True**23. The #8 captains of Houston will have a lower average team number than Detroit
**True**24. The same color alliance will win the Houston Championship as Detroit
**False**25. The winner of the Houston Championship will have a higher average score than Detroit
**True**26. There will be an even number of finalists matches played on Einstein
**False**27. The sum of the Chairman's Award winners will be even.
**True**28. The sum of the Chairman's Award Finalists will be even.
**17171**Tiebreaker #1 - Predict the sum of the team numbers of all Einstein champions (closest without going over wins)
**8400**Tiebreaker #2 - Predict the total points on Einstein (closest wins).
14481 Tiebreaker #1 - Predict the sum of the team numbers of all Einstein champions (closest without going over wins)
24481 Tiebreaker #2 - Predict the total points on Einstein (closest wins).
FALSE 13. Newton will score more qualification points than Daly
FLASE 23. The #8 captains of Houston will have a lower average team number than Detroit
10000 Tiebreaker #1 - Predict the sum of the team numbers of all Einstein champions (closest without going over wins)
10000 Tiebreaker #2 - Predict the total points on Einstein (closest wins).
9009 Tiebreaker #1 - Predict the sum of the team numbers of all Einstein champions (closest without going over wins)
20487 Tiebreaker #2 - Predict the total points on Einstein (closest wins).
FALSE 19. Newton #1 seed will have a higher ranking score than Daly #1 seed
22502 Tiebreaker #2 - Predict the total points on Einstein (closest wins).
Let’s see how this goes…
10,000 Tiebreaker #1 - Predict the sum of the team numbers of all Einstein champions (closest without going over wins)
10,800 Tiebreaker #2 - Predict the total points on Einstein (closest wins).
13082 Tiebreaker #1 - Predict the sum of the team numbers of all Einstein champions (closest without going over wins)
23082 Tiebreaker #2 - Predict the total points on Einstein (closest wins).
Had Google flip a coin. Heads is true, tails is false. Actually put thought into the Tiebreakers
10235 Tiebreaker #1 - Predict the sum of the team numbers of all Einstein champions (closest without going over wins)
19356 Tiebreaker #2 - Predict the total points on Einstein (closest wins).
Remember, you have until matches start in Detroit to enter! Thanks to everyone that formatted your entries correct, it helps a ton!
