2022 Houston World Championship Pit Map
Team #, Division, and Pit Space listing: https://www.firstinspires.org/sites/default/files/uploadedImages/Robotics_Programs/FRC/2022FRCDivisionsAndPits.pdf
Trying to get FIRST to use the folded-over alternating rookie-veteran pattern at champs:
Is there a map somewhere of this and its relation to the fields?
#CarverIsRigged
Getting the closest pit to the main entrance is pretty neat!
Has there been a field layout posted? wondering if I need to get the heelys out
I see your Heelys and raise you a RipStik.
#GalileoToo
Found this in app which seems to imply setup pretty much like 2019 - fields end to end but perhaps in a different order - with pits at one indeterminate end…
Never understood the order of the fields. Why not just alphabetical order?
SpacePoofs superpit?
Few people know this, but the champs fields are actually arranged to make your life as difficult as possible.
The magic algorithm takes thousands of inputs and then spits out a layout that gives you, personally, the most antagonizing possible champs layout. Even the bathrooms manage to be poorly positioned and a several minute walk away.
Bring back the scooters :sunglasses:
Did I miss something? Are scooters banned this year?
Edit: Just found it in the app, yep they are on the prohibited item list.
Wonder if I can get a medical exception lol, at least our teams pit is as close as possible.
