2D Port
We are transitioning from a 3D powerport to a 2D version today. Does anyone have pictures of how they set up their 2D port, that would be very helpful. As there seems to be some confusion in our team about the setup
huh
Lots of examples on YouTube:
https://www.youtube.com/watch?v=8VF-Z2u-2GM
https://www.youtube.com/watch?v=bbcTHii7bMs
https://www.youtube.com/watch?v=NNlEOdG8sb0
Plenty more if you look.
Like the videos @paulonis posted above show, you basically just need a wood cutout to insert into the 3D outer hole of the goal.
We found the simplest way to do this was to lay the goal down on top of a piece of plywood and trace the outer hole onto it. Then just cut it out, use some scrap wood to attach the pieces together and draw an appropriately sized circle in the middle of it.
thanks… this is helpful
