Very Late Post
Team Optix at the Ventura County Regional!
Team Optix competed in the Ventura County regional, posting a team-high record of 11-3, placing us at the 4th seed overall. This ties our teamâs record for our highest placement of our robot, and only in our first competition! At VCR, we had the honor of being alliance captain, selecting team 687 Nerd Herd and team 399 Eagle Robotics. Although we didnât end up qualifying for Houston, this was one of, if not the, greatest competition in Team Optix history, in both performance and consistency.
Build
Build did pretty well at Ventura! We did face a few challenges, but these did not restrict us from doing well in the competition. There wasnât a point at the competition where we were still working on the robot in the queue.
At inspection, we realized that there was a minor issue with our 4 bar: while actuating it, it extends past the 12 inch extension limit. We decided that it would be better to prioritize practice matches and fix the issue mechanically back in San Diego. Until then, software placed restrictions on the height of the arm, allowing us to compete. While at inspection we were also notified that our bumper material was too thin and might rip during competition.
The issue we faced most often was displacement of our 4 bar plates after almost each match. Through getting hit in matches, our plates would shift either to the left or to the right, and we would have to loosen collars in order to reposition the plates. In order to ensure this does not happen again and again we cut up pvc and used them as spacers on the bot. This allowed us to save time and complete our build checklists before matches rather than focusing a large portion of our time on reshifting the plates. Other than that, we had a match where our intake motorâs input stage broke, but luckily it was just the outer plating of the stage. We replaced it and didnât encounter any issue similar to that for the rest of the weekend. After a match, one of our 4 bar axles fell out due to a poorly tightened collar, but we had enough time to replace it. Our final issue was when we overtightened a standoff on the swerve module, and this prevented our function from turning, however we were able to fix it before going onto the field.
All in all, pretty minor issues, considering many issues were only a one time fix. Overall our performance as a build department was the best it has been.
Software
At Ventura, Software had our work cut out for us. By the time of the competition, we didnât have vision or a consistently tested autonomous. This is because itâs the first time weâve done a week two competition, meaning software had gotten an incredibly short timeframe to work on. As a result, we had to create an autonomous route throughout our competition.
Additionally, we also had to deal with issues with inspection. As mentioned before, we did not account for the arc of our intake throughout competition. This arc resulted in an extension limit of 13.5 inches as opposed to 12. Thus our intake method had to be changed, to where the arm was brought up, the four-bar moved, and the arm put down once again. While this did slow down the time it took for the intake, we still found it super effective throughout competition and the software fix enabled the success we found over the weekend.
Though we did not have a multi note autonomous routine, through good alliance selection, team strategy, and effective driving we were able to enter most playoff matches tied or even up after auto. Teleop further equalized the playing field as our subsystems were very well tuned leading us to consistent 8-9 note teleop matches ,
Electrical
Electrical went amazing for us at Ventura! We had 0 overall electrical issues through 14 official matches which has been incredible for our team.
Prior to Ventura, we finished updating our checklists and contingency plan. With our new state-of-the-art Dewalt TSTAK Clipboard, we were able to consistently keep track and organize our checklists for each match. We also completed our CBA testing, which we do prior to any of our competitions now. We test each battery through the âDischargeâ test under a consistent load of 7.5 Amps until the battery reaches the cutoff voltage of 10.5V, as specified under Team 1640âs documentation of how to CBA test batteries. Through the data weâve collected from our 9 batteries, we deemed 6 batteries as âcompetition usableâ as those batteries had a capacity of over 12 AmpHrs, while 3 of our batteries were downgraded to âPit Use Onlyâ Batteries as they had a capacity less than the competition expected.
Match, Time: Practice Match 4, 0:00 into Auto, Remainder of the Match
Issue: Battery Brownout for Battery #1
Cause: Battery Charge was too low
Pre-Match Factors: The battery may not have been properly checked, voltage reading may have been checked too soon after being unplugged from the charger.
Solution: We are unsure specifically why Battery #1 Browned out, as it was fully charged as confirmed on the Battery Beak and Charger before the match, and met battery capacity requirements as per our CBA Testing. We downgraded Battery #1 to âpit-use onlyâ until further testing could be done after the competition and put a higher emphasis on our electrical pit team to let the battery âcoolâ before measuring with the battery beak after taking it off the charger.
Awards
Our awards process went extremely well this year! We as a team created a brag sheet and outreach posters to ensure that we were effectively communicating with other teams and judges about our accomplishments as a team. At Ventura, we interviewed for the FIRST Impact Award, which although we did not receive, we had an amazing experience talking to judges and other teams about Team Optix Culture!
Scouting
Scouting went great for us at Ventura! We successfully scouted the majority of practice matches and all qualification matches (excluding our own), which has proven to be a massive positive for our team.
Prior to Ventura, we successfully finished the Optix Scouting App with the help of our software team. We then followed up on this with approximately 5 days of testing and making sure everyone on our scouting lead team of 3 people knew the game inside and out.
One challenge we did have was the constant lack of scouters. Ventura is an away competition for our team, meaning that we had limited people present at the event, and those who did show up often had to leave due to being called up to the pits.
We solved this by creating a schedule the night before for every single member present at the competition, which we would then send out in the morning to all our members. This reduced quite a bit of confusion as to how we would get 6 scouters to successfully scout all of our matches.
We also attempted to schedule people in blocks so they would only have one larger shift that they would have to scout for the entire weekend, making it a lot easier to balance scouting shifts given out to people: one person wonât have to scout more than someone else.
Overall, VCR has been an amazing experience for Team Optix, and we couldnât wait to see everyone at SDR!
Team Optix at the San Diego Regional!
Performance
While not matching the level of performance we had at Ventura, our overall performance as a team was still extremely solid. In qualifications, we went 5-4, placing 15th overall out of 51 teams. We were selected as the second pick on the 7th seeded alliance along with Alliance Captain Team 8119 TigerBotics and Team 1622 Team Spyder, both of whom weâd like to give our sincere thanks to for the playoff run. In the playoffs, we lost our initial match to Alliance 2, but then beat Alliance 3 in a close, but very unfortunate Match 6 where Team 9084 Octobots tipped over at the beginning of Teleop. We were unfortunately eliminated after advancing to Round 3, Match 9 in a tough match against the 5th seeded alliance. Overall, we ended SDR with an overall record of 6-6 throughout the regional, ending tied for 5th in playoffs, and had a blast ending off our season!
Build
Believe it or not, Build went even better at San Diego than at Ventura. On the practice day, the intake motor was oscillating and the acetal was giving out. We figured that issue out and got it fixed pretty quickly and sailed smoothly ever since. Saturday came with no mechanical issues, as did Sunday. We were able to run checklists and not have to run around, even having time to help other teams since we didnât have to help ourselves. Itâs been quite different from the years past, which I am very happy about. Hopefully we can continue this trend into water game!
Also we won the Excellence in Engineering award!
Software
Coming out of VCR, we had two big priorities:
- Have a 4 note auto
- Have auto-aim, and have that shoot from a distance
Both of these features had already had the bulk of their work completed prior to VCR and were just lacking the time needed for small debugging and fine-tuning. As a result, we accomplished both of these targets with great success.
Throughout the weekend, there were not one, but two stretches of 5 matches in a row where we did not miss a single shot in the speaker. And no, thatâs no subwoofer shots, but shots from anywhere closer than the podium. Thanks to field-pose estimation from our two limelights and our brand new pigeon 2.0 gyroscope, we were able to not only calculate the proper angle of our arm for shooting but also to auto-align the robot to shoot from the correct orientation. These two features enabled around a 95% accuracy from anywhere within the green ellipse drawn below:
Additionally, our autonomous led to great success on the field. Though in qualifications it was often interrupted by some colliding teammates or alliance partners who wished to start in the same location, a well selected playoff alliance enabled itâs prowess to shine through, scoring dozens of points in our 3 match playoff run. Watch a closeup video of our auto on the practice field with the link below!
2024-Auto.MOV
Electrical
We faced very few electrical issues during the San Diego regional and mostly had good performance. A few issues we faced were as follows. We had a broken JST connector for one of the SparkMaxes on our drivetrain, and had to crimp the JSTs again. We also had a disconnected CAN connection for one of our motor controllers, that we just had to reconnect. Our biggest issue started with our intake motor controller(the one which turns the polycarb rollers) whose status light didnât turn on and was unresponsive. We tried putting it in recovery mode but nothing about the situation changed. Assuming it was an issue due to the SparkMax, we switched out the Spark and sent the bot off to our final quals match as the light turned on when we tested. However, during the match, the intake didnât move, and upon inspection at the end of the match it looked like the status light for the new spark didnât turn on as well. Testing the old spark, we knew that it was broken, but it was clear that something external broke the spark. We connected a different motorâs spark to the same APP connection, and it worked fine, so we knew the issue came from the motor side and not the PDH. Thus, with help from Joe, a CSA at SDR, we were given a suggestion to switch both the spark and motor, and it worked from there. Playoffs went without a hitch, with the exception of having to switch out a 20A Fuse for a 10A Fuse for our VRM due to a rule violation R617, which specifies that any device powering the Radio must be protected by a 10A fuse. This issue had gone unnoticed until that point, as our team and many others were still in the mindset of the VRM being powered by a 20A Fuse as it is on the PDP. We made the respective changes and did not see any further issues.
Match, Time: Qualification Match 76, 0:04 into Auto, Remainder of the Match
Issue: Intake Motor (REV NEO 1.1) Not Working
Cause: SPARK MAX Internal Issue, NEO 1.1 Internal Issue
Pre-Match Factors: Motor and SPARK MAX were not properly inspected, motors and controllers not inspected prior to competition.
Solution: We switched out both the NEO 1.1 & SPARK MAX for new ones, which resolved the issue. Much of this issue was unavoidable due to it being an internal issue within the NEO 1.1 & SPARK MAX, however we are taking steps to do spare Motor and Motor Controller inspection prior to Competition.
Awards
At the San Diego Regional Competition we refined our impact presentation process with our new poster design. We were additionally much better prepared for talking to judges in pits, with our pit crew having a more in depth understanding of competitions following their second regional competition, eventually leading us to winning the Excellence in Engineering Award. Finally for the first time in Team Optix history, our Team President Noah Simon won the Deanâs List Finalist Award.
Scouting
Scouting at SDR went smoothly for us, building upon the lessons learned at Ventura. We once again effectively scouted the majority of practice matches and all qualification matches.
Following our success at Ventura, we once again utilized the Optix Scouting App, which we had successfully completed prior to Ventura with the assistance of our software team. Additionally, we conducted thorough testing on the Optix Scouting app to ensure that everything was still working and functional.
SDR being our home competition also allowed for a surplus of scouters at all times, which was thanks to our great member turnout at SDR. This removed the added stress of trying to ensure we had enough scouters during crucial moments, especially when we were swapping scouters because their shifts had just ended.
Another adjustment we made was to address the calendar flaws we encountered at Ventura due to people being unable to show up for their scouting shifts. To mitigate this issue, we set up alternate scouters whom we could call upon in case someone couldnât make it.
Overall, the lessons learned from Ventura were instrumental in optimizing our scouting efforts at SDR, contributing to our teamâs scouting success once again.
Team Optix is so thankful to end the season off with a great alliance and looking forward to the next season!
Contributors
Thien-Nam Huynh
Rudra Jani @rjani
Varalu Nibhanupudi @Varalu
Chinmay Ramamurthy @Chinmayr
Noah Simon @tubularturtle8
Sharanya Tripathi
Alexander Zhang @alexzhang3749
Photos
Mateo Adeppa
Katherine Chen
Offseason Comp Recaps Coming Soon
